Fixing Out Of Square Deck Posts - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-28-2010, 07:06 PM   #16
kwikfishron's Avatar
Rewards Points: 176
Originally Posted by Starbuck II View Post
moving what? the footing? the anchor point?
Please clarify
The Footing.
Iíve screwed up before, Iíve done this before and all is fine.
Iím sure Iíll get a thrashing for suggesting this.
kwikfishron is online now   Reply With Quote
Old 04-28-2010, 07:49 PM   #17
how tall are the posts on the footing and is a beam on this?
The older I get the better I was
Old 04-28-2010, 09:08 PM   #18
Old School
Willie T's Avatar
Originally Posted by kwikfishron View Post
The Footing.
I’ve screwed up before, I’ve done this before and all is fine.
I’m sure I’ll get a thrashing for suggesting this.
Most of us with any appreciable amount of experience in any industry have covered our butts with a host of creative solutions. Construction just takes more physical and dynamic fixes.
I have very little doubt that if we were able to lay eyes on the real world problem, you might have at least two or three possible ways out of this. As it stands right now, it is difficult for any of us to suggest 'outside-the-box' thinking because we are really not all that sure exactly what the box looks like.
As I said, we don't really know where and how and to what extent, on which columns you're off. And we don't know your plan of building or if it can be modified.
Think 'offsets' and/or 'cantelievers', and reversing direction on joist layouts, etc. Even enlarging the perimeter to 4 or 6 inches larger to give you space and flexibility to square up the outside rim. Ya gotta get outside the box on this one.
FranÁois Duc de La Rochefoucauld
Willie T
Old 04-28-2010, 09:57 PM   #19
Polk,
Posts are 8' tall, yes beams will sit on top of the posts with Simpson brackets.
Willy,
I am going to re string line the whole space to get more accurate measurements because it's difficult to see them as out of square given that none of the rim joists are 3" away from one post to another.
The shape is a rectangle with one corner lopped off. An exagerated view would be somewhat trapazoidal. There is a 12' side, adjacent to it is a 10' side. Adjacent to the 10' side is an 8' side. On the other end of the 12' side is an 8' side. The two 8' sides are connected by a 40" side.
I have since given some thought to cantilever, but I am concerned that The roof load isn't properly transferred to the footing.
Starbuck II is offline   Reply With Quote
Old 05-01-2010, 05:51 PM   #20
The posts are impossible to move unless I destroy them.
I think there really isn't any solution for making this square that doesn't involve totally starting over.
I think I found out one thing that happened for sure, a couple of the anchors moved during curing, about 1.6 degrees by my calc. I used a square laser to generate two perpendicular lines. It seems that a couple anchors are rotated slightly & a couple footings are off axis by 1" That combination seems to be what has generated most of my errors.
I think my only hope is to start the decking from the centre & work outwards towards the perimeter & fudge the gaps a little bit all the way across. leaving any error to be along the outside edges.
Not sure what else to do. Anyone else got any ideas? I have looked over cantilevering the post to the anchor, but that to me seems like it would weaken the support for the roof.
Old 05-01-2010, 05:55 PM   #21
Rewards Points: 176
Can you post some pictures?
Old 05-01-2010, 06:14 PM   #22
I will try but I don't think you would see anything. The errors are not obvious when you look at it. I am working on some sketches with dimensions that might give a better picture.
Old 05-01-2010, 06:37 PM   #23
Rewards Points: 176
I’d sure like to see a picture of your footings and the wall your building off of in the same shot. Don’t need to see out of square part in the picture.
Old 05-03-2010, 12:02 PM   #24
Yes, get a very accurate centrally located post and work out from that in a star pattern, rather than starting at one end and working around in a daisy chain. This second method adds each error to the one before it.
Double Level Deck 6x6 posts Skytree Building & Construction 3 09-07-2009 11:47 AM
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 08:03 PM
Deck Posts replacement with load bearing columns from Pacific Columns, Inc Bruce Wilson Building & Construction 7 05-24-2009 03:55 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
