Fixing Leaking Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 09:37 PM   #1
Fixing leaking garage
I am having water intrusion into my garage in between the cinder block walls and the poured concrete floor.
The house is a bi-level built in 1982. The garage doors are on the rear of the house. The water is coming in on the front of the house (lowest point of the house is the garage floor) My dad helped me seal where the poured concrete meets the cinder block with drylock fast plug and I though for sure this would work. Nope...garage flooded again. It just appears that the water is coming in at the seam, even after the fast plug was put down and cured, water appears to be coming from the same place as before.
I'm beginning to get frustrated. Not sure what to do
mk3vdub is offline   Reply With Quote
Old 03-10-2011, 09:52 PM   #2
Rewards Points: 262
You most likely have to redirect that water away from your garage foundation with some sort of drainage system. Any amount of sealing you do will only be a temporary fix and the water will just find another way in. Pictures of the problem area might help get answers.
Jim F is offline   Reply With Quote
The Following User Says Thank You to Jim F For This Useful Post:
oh'mike (03-10-2011)
Old 03-11-2011, 11:11 AM   #3
Remodeler
Rewards Points: 298
Move downspouts away and make sure that the grade slopes away from the foundation for several feet. That will help redirect surface water, but most likely won't fix the problem.
You must either deal with the water before it comes in or install a french drain to get the water to a pit after it comes in.
To actually fix it you will likely need to dig down to the footing around the perimeter so you can seal the footing and wall with a foundation coating and membrane; then install drainage tile and gravel to carry the water away either to a downhill location or to a sump pit so it can be pumped away.
A french drain is a channel that goes around the inside of the wall to collect and control water that does get in. Holes are drilled at the bottom of the block wall to allow water that gets into the block wall to drain away. This method doesn't seal up the leak it merely controls the water that does get in so you don't have a wet floor.
There is no method you can install that will permanently seal the wall from the inside, if water is pushing on the outside it will either leak in or push the wall in. You have to drain it away one way or another.
iamrfixit is offline   Reply With Quote
fixing a leaking drain Millertyme Plumbing 1 09-12-2010 11:00 AM
Fixing a Flooding Garage Earthworm Jim General DIY Discussions 4 05-03-2010 09:20 AM
Fixing a moldy spot on wooden garage roof Earthworm Jim Roofing/Siding 1 04-30-2010 10:46 PM
Basement Garage with Concrete Slab: To Vent or not to Vent N-GA-Homeowner Remodeling 3 05-29-2009 07:13 AM
Fixing leaking shower head...turns out pipe coming out of wall is the source plumbingboy9317 Plumbing 5 05-25-2009 02:41 PM
