Fixing Drywall Mud Flaws AFTER Primer - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-25-2013, 08:24 AM   #1
Lightbulb
Here is the sum of things:
Remodeling sun room with all new drywall, about 13x30. Ceiling has been primed and flaws are showing up at some of the seam/joints where the drywall comes together. I have been told that once primed you cannot fix flaws but I find that hard to believe.
How do I fix mud flaws after priming? It is more than just bubbles so I'm in need of advice here as I would prefer not to texture my ceiling.
Thanks in advance for all advice provided.
SabertoothBunny is offline   Reply With Quote
Old 01-25-2013, 08:27 AM   #2
AHH, SPANS!!!
Rewards Points: 1,166
out drywallers always came back after prime coat to touch up, the prime coat helps to show flaws/shadows that go unseen with just bare drywall. if you need to knock off heavy edges do so with a putty knife and sanding still works, just not as effectively as before prime coat. you can pull mud over top the prime coat all day long...
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
woodworkbykirk (01-25-2013)
Old 01-25-2013, 08:39 AM   #3
Rewards Points: 13,750
Happens to even the best of them, do not be so hard on yourself.
Old 01-25-2013, 10:42 AM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
hand drives right.. after the first coat of paint even drywallers have to come back to fix missed spots and dings in walls caused by subtrades
woodworkbykirk is offline   Reply With Quote
Old 01-25-2013, 12:10 PM   #5
Rewards Points: 4,796
Of course that is not true. If that were true, you'd never be able to patch a wall at any time after it's painted.
Sand first if necessary (primed surfaces are harder to sand than unprimed.) Patch or touch up with compound. Resand if necessary. Spot prime over the patches.
jeffnc is offline   Reply With Quote
Old 01-25-2013, 01:04 PM   #6
Rewards Points: 4,656
hand drive,,, gotta LOVE that logon name
The Following User Says Thank You to stadry For This Useful Post:
hand drive (02-20-2013)
Should Primer be Tinted on New Drywall?? My painter says no. Pete33 Painting 20 08-13-2012 10:24 AM
Primer choice on New Drywall zhtway Painting 11 07-04-2012 04:34 PM
NEW DRYWALL, new addition, Need Primer chipraynor Painting 50 11-09-2011 11:45 PM
drywall primer choice autx790 Painting 16 11-08-2011 05:25 AM
Primer Over Drywall dgoldb1 Painting 16 03-03-2008 04:37 PM
