Old 09-28-2009, 12:11 PM   #1
Default fixing drive/walkway issue
Hello everyone- I'm new to the forum.
My house (Circa 1984) was built with a tiled driveway and walk. Unfortunately, the thin tile (approx. L 7" W 4" D .5") applied to the concrete driveway with thin set mortar has begun to come up. Many pieces have split in half...or cracked off near any edges of the drive or walk way. I'm told that the initial installer explained that the tiles were too thin to put down for this application, but the owner didn't listen.
I also know that there are several areas of the concrete drive and walkway- are either majorly cracked or broken...obviously causing the tiles to pop off in that section.
I'm curious as to what the best- most economical course of action would be to not only correct this issue, but also update the look of the drive/walkway.
My thoughts are to;
OPTION 1:
Jack hammer up all the tiles AND the thin set mortar on top of the concrete. Next, fix any concrete issues that are apparent. Next lay down some type of Mastic application that would allow the new tiles to 'move' under pressure.
OPTION 2:
Resurface the existing concrete using either a stamped application or something similar.
Any thoughts and/or advice on the matter would be GREATLY appreciated.
Roger
puma69 is offline   Reply With Quote
Old 11-01-2009, 10:03 PM   #2
I would definetely choose option 2, you must live in the south, never heard of a tiled driveway and would never even imagine it even in a warm climate. You may also consider pavers, check the manufacturers info on installing over existing concrete, I just put in pavers over a concrete patio in my back yard, came out nice, used grinnell 5 piece randam
pbert is offline   Reply With Quote
Old 11-02-2009, 06:05 AM   #3
Default w/newer mtls avail today,,,
why even bother replacing anything but think chipping gun, not j-hammer,,, resurface w/polymer-modified cementitious products,,, we use elitecrete which's very easy to apply ( just add wtr ),,, many projects down here in the south have tile but we get jobs replacing/repairing all the time.
you'll need to scarify the surface after chipping off the old tile down to original conc - make nec repairs - then broom in the 1st coat per directions,,, we squeegee on the next coat ( or 2, if nec ) then finish w/broom,,, you may decide on another finish.
btw, no suitable mtl's avail at ANY apron store nor is best/inexpensive ever compatible/available.
itsreallyconc is offline   Reply With Quote
More On This Topic
I’m Lee; I have a degree in architecture, about ten years experience in the construction field, and today we’re installing a designer countertop. Now we want the mortar on a countertop to be mixed thicker than on a floor. On a floor, you want... Read More »
How to Trim Tile
How to Trim Tile by eHow.com
Applying tile to a room can add interest as well as accentuate architectural details. Choosing the right tile for trim is very important and can add the proper finishing touch that makes or breaks a project. Read this article to learn more. Read More »
No matter what type of driveway you have--concrete, asphalt or gravel--you are at risk for developing potholes. Potholes are caused by water penetrating the surface of the driveway. In the case of concrete and asphalt, the water builds up under the... Read More »
Hi, I’m Faith and I’m with Flat Fork Studio, and I’m here to discuss the different kinds of adhesives that you might want to use in doing your tile mosaic project. There’s several different applications. You first need to decide... Read More »
If after a rain you notice water collecting underneath your brick stairs, then you may have a brick stair leak. Afraid that you will have to spend thousands of dollars to have your stairs rebuilt? Slow down--this might not be the necessary solution. Read... Read More »
AC condensate issue cleddy HVAC 1 08-02-2009 11:26 PM
Interlock Paver Issue cbadrik Landscaping & Lawn Care 2 07-27-2009 09:29 PM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 05:14 PM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 03:34 PM
Fireplace framing/tile issue robdville Building & Construction 13 11-14-2008 09:14 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
