Fixing Dent On Window Rounded/bullnose - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-10-2007, 05:00 PM   #1
Fixing dent on window rounded/bullnose
Hi,
I have a 2-3 inch dent on window seal. The corner is a bullnose/corner seal. I would like to try and fix it but worried that if i try to pull the dent out it may break. Does anyone have any good ideas on how i can tackle this problem?
adviner is offline   Reply With Quote
Old 06-10-2007, 06:56 PM   #2
Are we talking on the Sheetrock rounded corner or on the window itself. If you could post a picture it might help (if it is on the window itself). We might not be able to see the dent but we could get a feel for what you are up against. If it is on the Sheetrock corner you need to fill it with hot mud then get a can of texture then spray it to match your walls.
warnerww is offline   Reply With Quote
Old 06-10-2007, 11:43 PM   #3
Rewards Points: 5,336
I'm also confused. What material is dented? Is this bullnose/corner seal part of a window?
Ron
Old 06-11-2007, 06:21 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by adviner View Post
I have a 2-3 inch dent on window seal. The corner is a bullnose/corner seal....
Sounds like it is a vinyl window and possibly a removable sash that got dropped and dented on it's corner (?)
If that is the case, I have no experience with ''fixing'' or repairing'' these. A 2" to 3" dent sounds like pretty serious damage, the only thing I could suggest is to order a replacement sash from the manufacturer.
- Build Well -
Shrink Film Window Insulation miserlou General DIY Discussions 10 11-24-2008 06:19 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
I blew it on the mesurements.Vinyl window Doug Crf Remodeling 6 03-29-2007 10:06 PM
Window jamb helpless handyman Carpentry 11 08-03-2006 12:45 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-13-2005 11:59 PM
