Fixing Brick Over New Exterior Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-26-2008, 03:27 AM   #1
Just thought I would here and take evasive action. Our "contractor" install a new pella double french door in an exterior brick/cinder block wall. There was a 32" door there previously and it was enlarged to install the 6' french doors.
A new header was installed on the interior. However the exterior brick facia is not yet complete. There is a gap above the door where the brick needs to be put back in.
What SHOULD the correct process be to do this? The old lintel? is still in place yet not long enough as you can guess.
My guess is - they are going to install the bricks over the door and just rest them on the top of the door itself. I know this is NOT the correct way.
So - how should this be done?
Thanks!
AbSoluTc is offline   Reply With Quote
Old 01-26-2008, 04:00 AM   #2
ICF Construction
Well unless he's a magician he will be installing a new lintel that covers the entire new door and embeds into the brick joints on either side of the door, similar to what the previous lintel was doing.
Rebrick the area affected and you should be done, plus chalking, plus painting the lintel if that applies, etc...
Chris
Chris Johnson is offline   Reply With Quote
Old 01-27-2008, 05:12 PM   #3
remodeling pro
Your guess about that being the wrong way is dead on correct. A couple of rows of brick have to be carefully removed and a new full length steel lintel of proper depth installed, then rebricked. This is a job for a mason, not the obvious clueless guy that left the brick currently unsupported. My best hope is that this is a location where you have a minimal amount of unsupported brink currently hanging by the brick ties, and not in a two story or gable wall with much brick above the unsupported opening. If so, this lintel installation is urgent, get it done pronto!
troubleseeker is offline   Reply With Quote
Old 01-27-2008, 09:34 PM   #4
Rewards Points: 1,220
Actually, it is more dangerous to leave unsupported masonry in a narrow band above a door than a gable end. If the height of masonry above unsupported masonry is equal to at least one and a half times the width, the chances are the masonry will support itself. Anything less should be shored. Regardless, a full length steel lintel should be installed before re-bricking.
Tscarborough is offline   Reply With Quote
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 05:26 PM
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 04:07 PM
Cheaper masonry alternatives to brick? Jemo Building & Construction 9 05-18-2007 01:31 PM
Brick: to paint or not to paint, that is the ? Turnip Painting 3 04-15-2007 11:06 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
