Fix Squeaking Subfloor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 01:47 AM   #1
fix squeaking subfloor
Dad and I are building a new subfloor in my enclosed one-car garage. Used joist hangers and 2x6's with 16 inch centers. Joists are 10' 9". We supported each of the joists in the middle with blocks screwed into the concrete and then glued and screwed to each 2x6. Everything level and seems solid.
Started glueing and screwing the 3/4 t&g osd panels down (liquid nails, 2.5 in deck screws). After 2 panels, we get a pretty noticeable creaking when walking on top.
Not sure what's causing it. Wondering if we need to block between joists, use something besides 3/4 osd or put plywood or another layer of osd on top of what we have. Planning on carpeting when subfloor is done. Maybe that will help?
Any thoughts or suggestions appreciated!
Stephen
stev9erphi is offline   Reply With Quote
Old 12-30-2011, 05:08 AM   #2
Retired carpenter
You seem to be doing everything correctly.
Only thing I can think of:
When you screw down your sheets, are you doing first the perimeter and then working towards the center? That could cause a squeak by leaving bumps in the middle. Always start on one end and work towards the other end, while putting your own weight on the spot you're screwing down. For screws, I would also predrill the holes, to make sure that the sheet gets sucked all the way down against the joist.
abracaboom is offline   Reply With Quote
The Following User Says Thank You to abracaboom For This Useful Post:
stev9erphi (01-02-2012)
Old 12-30-2011, 07:40 AM   #3
Joints are not supposed to be tight, but should have about a 1/8" gap. Too tight could cause squeaks, rubbing edges. But, if screwed at each joist, and close to the edge, that should not be a problem.
Old 12-30-2011, 07:57 AM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I've never pre-drilled, but like abracaboom says, make sure you stand on the area you are screwing to suck it down good.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-30-2011, 11:06 AM   #5
Residential Designer
AndyGump's Avatar
Rewards Points: 662
Send a message via Skype™ to AndyGump
Can you explain what this means?
I just didn't follow it like the other guys did.
Andy.
AndyGump is offline   Reply With Quote
Old 12-30-2011, 11:27 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
They have installed (too light) 2X6's for floor joists spanning 10'-9" (over spanned) but then they have added blocks to tie the center of the 2X6's to the floor, screwing the blocks to the floor.
If each panel is getting glue and the glue has had time to adhere and set up then the only other friction-point must be the end of the joists hanging in the hangers and rubbing the face of the (whatever you there). Or the seams of the panels are moving.
XXX
Old 12-30-2011, 11:38 AM   #7
AndyGump's Avatar
Rewards Points: 662
Actually, 2 x 6 s on 16" centers just barely makes it at 10' 9" if you consider 10 lbs. dead load and 30 lbs. load using DF #2.
I don't understand if he is making aloft in the garage or if he is actually putting this new floor on the garage slab or what the heck he is doing.
Or does he mean that they installed blocking at the ends of the joists, on the conc. block walls then nailed the joists to the blocking hanging on the block walls?
All too vague.
Andy.
Old 12-30-2011, 03:13 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
XXX
Old 12-30-2011, 03:27 PM   #9
Retired carpenter
They are turning the garage into living space, and building a new floor just above the concrete floor because the concrete floor looks crappy and possibly had an oil tank underneath it. Also, the new floor will be level with the rest of the floors in the house. They used wooden blocks to cut the span of the 2x6s in half.
Old 12-30-2011, 03:41 PM   #10
Rewards Points: 2,210
Could the joists be moving in the hangers? Are there joists with no subfloor on it? Walk on these and do you get squeaking?
Or the sheets tight to the wall and squeaking as the floor flexes.
mae-ling is offline   Reply With Quote
Old 12-30-2011, 03:46 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Now that might be a RED FLAG.
XXX
Old 12-30-2011, 04:14 PM   #12
AndyGump's Avatar
Rewards Points: 662
O.K. how can you be so sure of that out of the single post?
If that is so then they could have used 2x4 if they wanted and I hope they used PT and not just DF.
Hey Steve, answer some questions will ya?
Andy.
Old 12-30-2011, 06:25 PM   #13
Thanks guys... sorry for vagueness. Abracaboom caught it all. Garage floor slopes 2.5 inches down. Wanted to level it without pouring concrete.
Screwed 2x6's running the length of the room into the concrete (pier and beam so it runs a foot off the ground around perimeter of garage). The 2x6's are level, then used joist hangers off the 2x6's. Then put blocks in the middle of the joists to cut the span - screwed and glued into the floor and into the joists to keep it all supported and level.
3/4 t&g osb on top of that with liquid nails and screws.
Joists are anchored with 2.5 screws through the hanger into the 2x6 running the length of the room, so they're not moving. When the panels were loose on the joists (before screwing) they didn't make much noise, if any.
We didn't screw as we went though. Maybe that's the problem. Put a few screws in randomly and then started going down the row. Seems to be flexing in between the joists. We stopped after 2 to figure out what was wrong. Thinking I'll try more glue, more screws, and moving from one end to the other while driving the screws on the next row and see if that does it.
If not, what are your thoughts on putting down another layer of boards? Read somewhere that 1/2 ply might be good on top.
Thanks again!
Old 12-30-2011, 06:48 PM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Did you cross-brace or block the joists?
XXX
Old 12-30-2011, 08:37 PM   #15
Retired carpenter
I'm a carpenter.
How should I reinforce this subfloor? NewHomeDIYGuy Tiling, ceramics, marble 35 12-05-2011 11:01 AM
How to flatten subfloor hump? loftezy Flooring 9 11-15-2011 01:53 PM
squeaking subfloor asiatheboxer Flooring 9 09-13-2011 08:53 AM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 08:39 AM
