Fix Shed Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-13-2012, 06:33 AM   #1
Fix shed foundation
Hey all. I have a question on a shed foundation that I need help on. 8x12 shed on sloping ground about 15-18" drop, front to back. The front (12 foot side) is sitting on 3 4x8x16 blocks and the back (12 foot side) is on 3 4x4 posts on pre-cast blocks (dek-blok). All flooring is 2x8 framing, with the 12 foot sides doubled. My question is how could I pour concrete footers on the back side to aid in stabilization/strength? This is an existing shed and tear down/move is not possible. My plan was to dig 3 42" holes along the back side (one at a time), fill with concrete, attached a post base and then place a 6x6 under the back side of the shed. Will this work? The shed hasnt moved, settled and is still square but I want to make sure it doesnt move, settle or go out of square. Thank you.
ctvader is offline   Reply With Quote
Old 10-13-2012, 08:07 AM   #2
Rewards Points: 1,166
temporary support bracing underneath of the structure to hold up its weight while you do the work to pour the new footings. Take all of the support bracing down when you have the footings poured and can put the weight down onto them...
hand drive is offline   Reply With Quote
Quick Garden Shed Foundation Question casper129 Building & Construction 4 04-17-2012 12:40 AM
Foundation for PVC Shed Nospammer Building & Construction 2 06-16-2011 08:06 PM
floor foundation for a metal shed forever0082 Building & Construction 5 07-02-2010 09:08 AM
re: small metal shed foundation gramps416 Building & Construction 12 06-04-2010 03:25 PM
Arrow shed on angle concrete foundation - how to fix? norcalty Building & Construction 4 06-18-2009 06:28 AM
