Fix A Scratch/mark Inside Porcelain Tub - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-14-2009, 10:49 PM   #1
Fix a scratch/mark inside porcelain tub
I have a spot inside my porcelain tub that looks like eventually it could rust and cause a hole. Its about the size of a dime right now.
How do i fix it?
thanks
I'm a newbie to home improvement...but I want to learn.
Fix a scratch/mark inside porcelain tub-p1010603.jpg
limitdiy is offline   Reply With Quote
Old 08-15-2009, 07:08 AM   #2
Remodeling Contractor
use a colored epoxy. Sand with 600 grit wet sandpaper then sand to a polished finish with same paper increasing grit to 1500. Then polish with a buffer.
sealing INSIDE an exterior wall penatration measure thrice Electrical 1 01-24-2009 03:12 PM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 04:05 PM
Porcelain on Cast Iron Tub controlnovice Plumbing 1 08-16-2008 11:36 AM
new ( to me ) house... cold inside, warm outside... what's the deal? MrLinux General DIY Discussions 7 02-13-2008 09:33 PM
