Fix A Sagging Roof Ridge...?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-06-2009, 09:59 AM   #1
fix a sagging roof ridge...??
Hi,
I've got a bit of a problem I need to figure out. I've put a new dormer on the back of my house, and now I need to make the old roof on the front of the house meet up with the new ridge. The problem is that the new ridge is nice and straight and level, but the old roof sags about 3 inches in the middle. The old roof is just 2x4 stick frame.
View from front:
Current profile:
My plan is to put in a knee wall and run a 2x8 rafter from the exterior wall to the knee wall, and from the knee wall to the new ridge.
Proposed profile:
Does this look OK? The building inspector doesn't have any requirements for the old section of roof.
thanks in advance!
red86yota is offline   Reply With Quote
Old 02-06-2009, 09:37 PM   #2
Old School
Willie T's Avatar
While you're checking out that "sag", take an eyeball down the ridge line, from gable to gable. Chances are, your sag could be coming, at least in part, from the ridge bowing to one side. I know you said it looked straight, but did you put a stringn on it?
Just something to be aware of. It might influence your intended method of repair.
Willie T
Old 02-06-2009, 09:46 PM   #3
Originally Posted by red86yota View Post
Hi,
View from front:
Attachment 8049
Current profile:
Attachment 8050
Proposed profile:
Attachment 8051
thanks in advance!
Usually when the ridge sags, the 1st floor walls are forced outwards by pressure exerted from the rafters. If the wall doesn't move out, the birds mouths open because they were improperly fastened.
To pull this back will be most difficult! Your knee wall is a good idea, to reinforce the rafters.
After placing the knee wall, I'd be inclined to run external stringers, lateraly with shims to level them off, then re-sheet the roof on the stringers.
low-slope roof and leaky ridge vent downers Roofing/Siding 15 02-22-2008 12:35 AM
sagging roof, rotten ridge board sonoflee Roofing/Siding 6 01-29-2008 07:12 PM
Ventilating Roof with no ridge? NateHanson Roofing/Siding 7 12-30-2007 05:33 AM
