Fitting A Smaller Storm Door To A Larger Frame? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-17-2011, 08:31 AM   #16
Rewards Points: 5,332
Originally Posted by gregzoll View Post
I hired my guy, because the work I was having done was beyond the fact that he knows how to do the roof work, so that it does not leak. The same reason that when you have a door like the OP, you use the proper materials to complete the job. That means if you have to order a door from the manufacturer to fit the opening, you do it. What you do not do, is place a board at the top of the doorway to make up for an odd size opening.
Only if you know what you are doing, you can make it work, but nine times out of ten, you can notice when someone does a job like this incorrectly. If it was me, I would be ordering a custom sized storm door, not frame out the opening smaller.
The guy has a door alrerady. He's not getting a custom sized door because you think that's the way it should be done.
He asked how he could use it and I told him.
Will it look odd? Maybe, but that's his call. He spends some time putting it in and then he looks at it. If he's happy with the money saving solution, end of story.
Like I said in the beginning, DIY'er's are in it to save money on the job. Sometimes looks are compromised. Not my call. It's when function and/or safety is compromised, I advise other solutions.
Bottom line, it's their house, they can do what they want.
Ron
B. Franklin 1759
Changing wire gauge larger to smaller maurice53 Electrical 0 05-15-2011 04:41 PM
Going from full-screen frame to the original smaller frame proofer PC Repairs & Upgrades 3 04-10-2011 01:11 PM
Storm door mounting area - one side (jamb) is smaller than the other. joe_p Windows and Doors 4 04-07-2011 02:26 PM
Water heater: larger and lower temp, or smaller and higher temp, energy use HVAC_NW Plumbing 1 10-11-2010 09:38 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 05:30 PM
