Fitting Joists For Loft Conversion - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-03-2009, 01:31 PM   #1
Fitting Joists for loft conversion
hi.i'm thinking about converting my loft into a single bedroom.at the moment i have 4.5x1.5 joists in it.i have a supporting wall thats goes 3/4's of the way across the loft.i'm thinking about sistering the new joist but not sure what size to fit.my other problem is that the joists after the supporting are roughly about 24 feet from wall plate to wall plate,i think i'll have problems fitting new joists that length or is there a way i can join them even though there is no supporting wall underneath them.
sparky dave is offline   Reply With Quote
Old 03-03-2009, 04:40 PM   #2
Registered User
Termite's Avatar
You have 1-1/2" x 4-1/2" floor joists spanning how far? Or are we talking ceiling joists here?
If this is a floor, you're waaaaaaaay undersized and need a serious re-design.
As for breaking/splicing the joists out over the span, no. Can't do it. You can certainly break them over the wall, provided it is a bearing wall. Perhaps a header could be added to support them in the area where the wall stops.
Old 03-03-2009, 05:13 PM   #3
Is it spanning 24' from the inside wall to inside wall?
You don't count the actual wall width, not that it will gain you much
I'd say your are into LVL or I-beams at that distance
I went with I-beams at 19' instead of 2x12's
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 09:43 PM
help with 2nd floor joists g heil Building & Construction 5 09-12-2008 07:41 PM
Best subfloor and material thickness nugentcn Flooring 7 09-07-2008 01:48 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 06:30 PM
Spacing of ceiling joists Pineconeman Building & Construction 3 05-14-2005 12:16 AM
