First Time Shower Tile Blues - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-25-2011, 12:03 AM   #1
Rewards Points: 562
first time shower tile blues
I was doing tape on cement board and found how NOT sticky self stick tape for cement board is. Normal? or better brand?
I am going up 5 ' above tub with tile line. Above that I used dens shield drywall,,,do I use thinset like cement board to tape or drywall compound???
how many coats of thinset does it take? for the newbie? Used to doing drywall,,first time cement board tape job.
If I find a high spot tommorrow,,,cut it off with sharp end of knife???or rub with cement brick rubber with a handle on it.??? Do you sand at all?
just trying to get something right the FIRST try!!!
4just1don is offline   Reply With Quote
Old 08-25-2011, 12:29 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yup, I'm afraid so. In the future you can wipe away the dust with a damp sponge and let the board dry thoroughly then apply the tape.
So you are painting above the 5' mark?
Usually one is enough.
Don't know why that would happen but yes you can brick-rub it.
Do you sand at all?
Nope.
XXX
question on tile shower design racebum Tiling, ceramics, marble 19 12-19-2010 03:48 PM
time between tile & groute ok_cntrygrl7 Remodeling 6 05-20-2010 10:19 AM
Shower leaking need to re tile Ineedhelp2009 Flooring 199 02-23-2010 06:46 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
Turning a tile shower into a one piece shower... chimera Remodeling 12 03-14-2009 03:30 PM
