First Time Hanging Drywall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-09-2011, 09:06 PM   #1
First time hanging drywall
I'm putting drywall in a commercial kitchen. I have purchased 4x10 sheets. The ceiling is 10ft 1 in. What is the best way to fill in the gap. Should I hand it flush to the floor and leave the inch on ceiling or vice versa. Any help would be greatly appreciated.
Thxs
Cosmiccharlie is offline   Reply With Quote
Old 01-09-2011, 09:12 PM   #2
Experienced
Jackofall1's Avatar
4 x 10 x ? 5/8 if its commercial I believe it needs to be 5/8"
What kind of ceiling?
Is the ceiling up?
Leave the 1" at the bottom, you'll have to do some kind of trim at the bottom with or without gap.
The Following User Says Thank You to Jackofall1 For This Useful Post:
Cosmiccharlie (01-09-2011)
Old 01-09-2011, 09:14 PM   #3
Rewards Points: 558
Thxs
In commercial drywall installation it would be hung vertically so cut the sheet down to 10’-0 ¼’’ and you should be good to go.
epson is offline   Reply With Quote
Old 01-09-2011, 09:19 PM   #4
Building inspector said half inch was fine it's just cosmetic. We are hanging over the existing drywall which was pretty well beat up
Old 01-09-2011, 09:28 PM   #5
Rewards Points: 558
As long as the building inspector is happy you will be happy…
Old 01-09-2011, 09:30 PM   #6
Experienced
Jackofall1's Avatar
you don't need 5/8 cause you are going on wall board already.
Old 01-10-2011, 11:31 AM   #7
Put a strip of 1/2" cdx on the bottom which will be hidden by the baseboard
mrgins is offline   Reply With Quote
Old 01-10-2011, 03:24 PM   #8
I agree about the "gap" definately being on bottom, as said the base should cover it.However you may wanna go a little higher...if a suspended ceiling is going in they'll need to attach their M7 to the top of your drywall.The base should be at least 4 inches, I'd recommend raising yer drywall a couple inches just to be safe.
alanshirley is offline   Reply With Quote
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Hanging Drywall to a finished Ceiling, Seam Questions? Worker-B Drywall & Plaster 5 08-24-2009 09:40 AM
Hanging Drywall ??????? mjkpainting Drywall & Plaster 11 04-23-2009 04:01 PM
Hanging drywall basement ceiling from engineered wood I-beam joists ja_trusty Building & Construction 6 10-09-2008 11:06 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
