First Time Cementing Anything - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-22-2012, 04:05 AM   #16
Yeah Im already having second and third thoughts. We will probably just wait till we can afford it.
Thanks all
Sartrean is offline   Reply With Quote
Old 01-22-2012, 06:11 AM   #17
Rewards Points: 3,130
Thanks all
Good plan. Some things are simply not a DIY job. I've done a few concrete jobs (small patios and such) and built my own log house virtually by myself. Yet I can't imagine tackling something like your driveway.
Old 01-22-2012, 01:26 PM   #18
Rewards Points: 268
You may look in to the option of crushed limestone and have it rolled. Not sure how thick you would want it, but if you have it rolled and once it is rained on and driven on a bit, it will make a good driveway. That's what I have for half of mine!
packer_rich is offline   Reply With Quote
Old 01-22-2012, 01:52 PM   #19
Msradell's Avatar
Rewards Points: 210
Actually since you live in a cold climate area asphalt maybe a better option. It remains a little flexible so it can better handle forces put on it by the freezing and melting cycles of winter time. These forces quite often crack concrete unless it is installed perfectly.
Msradell is offline   Reply With Quote
Old 01-22-2012, 09:53 PM   #20
Hm I never heard of using limestone for driveway I ll have to research it
Old 01-22-2012, 09:54 PM   #21
I did not think of that. Thanks for the advice. I will look into that as well and see what the cost will be. Thanks
Problems, GE SunSmart Digital Timer 15312 Mike Muls Electrical 41 07-30-2016 08:13 PM
Polyurethane Curing Time? 1simple Flooring 2 01-03-2011 06:11 PM
Cycle time Yoyizit HVAC 2 06-29-2009 07:10 PM
Can I grout a little at a time? yummy mummy Tiling, ceramics, marble 5 06-16-2009 01:21 PM
Sump Pump cycles 3-8 times each time it runs Delegator Plumbing 2 04-06-2008 12:48 PM
