Firming Up Cottage Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-20-2011, 09:30 AM   #1
Firming up cottage foundation
I have a 20 ' by 30' cottage built on a slope so one short end is on the ground and the other is on 6' wodden posts on concrete pads..
The ground is basically sand. I can feel the cottage sway slightly at times so I would like to brace it. The problem is that the solution needs to be adjustable. I was thinking of something like 4 teleposts and some kind of threaded rod cross bracing, are there any products available for DIYers.
patadams is offline   Reply With Quote
Old 03-20-2011, 09:54 AM   #2
why adjustable
The older I get the better I was
The Following User Says Thank You to tpolk For This Useful Post:
concretemasonry (03-20-2011)
Old 03-23-2011, 10:00 AM   #3
Adjustable requirements
Because the foundation is on concrete blocks on sand it is fairly standard to level your cottage in that area every few years. The alternative would be to pour a proper foundation whihc would be expensive
1920 Lakeside cottage on jacks- Foundation TROUBLE VelvetParis Building & Construction 15 03-21-2011 09:30 AM
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 12:27 PM
moist soil under raised foundation during winter bn300 Building & Construction 0 09-17-2010 02:51 AM
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 08:34 AM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 10:26 PM
