Firewell Install Between Heat Duct And Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-04-2013, 08:32 AM   #1
firewell install between heat duct and floor
i had a housing inspection and the inspector coded me on not having a type of firewall protection between the heat duct going thru the floor and the upper floor. can someone tell me what i need and how to install that. does it have to be sheet metal and if so do i have to remove the duct or can i work around and how big does it have to be ? confused and want to pass inspection
swirlmid is offline   Reply With Quote
Old 05-04-2013, 12:30 PM   #2
in western ny any penetrations between floors were required to be fire caulked to seal them. this included plumbing pipes, wiring and heat ducts. check with your building inspector on what is required in your location.
Old 05-04-2013, 12:51 PM   #3
An old Tradesmen
Rewards Points: 7,802
Moved to Building and Construction forum.
Old 05-05-2013, 07:51 AM   #4
Rewards Points: 3,130
What the inspector is talking about is called fireblocking. By blocking airflow, it prevents a fire from traveling to upper parts of the house through the openings for piping, ductwork, wiring, etc. The easiest way to seal these is with expandable firestop foam. Any big box store carries it, and it's not expensive. For larger openings, such as for ductwork, you may be able to just stuff some fiberglass insulation around the duct. I was allowed to do that when I built my house. But you really need to talk to the inspector about your location's specific requirements.
The Following User Says Thank You to md2lgyk For This Useful Post:
mae-ling (05-05-2013)
8" heat duct passing through floor Fulton Insulation 1 09-22-2012 01:46 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
