Firewall Code - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-12-2012, 12:41 AM   #1
firewall code
I built a 30x30x10' Pole building garage. It is 4' from the property line. The inspetor told me that new 2012 code says that I have to 2 hour firewall the end near the property line. I did what he asked. I sheeted both sides of the wall with 5/8'' Fire Curb type X sheet rock. He came back to check the firewall before I sided over it. He then said that all seems have to be blocked or mudded and taped. Again I did what he asked and mudded and taped all the seems. He came back and inspected the wall again. Now he tells me that I cant use the 5/8'' flame Curb on the exterior wall and I have to resheet over it with another kind of fire rated sheet rock. So he failed the firewall inspection even with me doing exactly what he told me to do. Is he right? Am I right? I mean what is going on,this is rediculous. Its just a garage.
eric5170 is offline   Reply With Quote
Old 07-12-2012, 07:02 AM   #2
Rewards Points: 40
Perhaps the inspecter is just getting up to speed on the 2012 code. Have you asked for a pamphlet or copy of the code? It sounds like you drywalled the interior and exterior of your wall with the same product which probably would not be rated for exterior use. Would it satisy him to put a double layer on the inside? Ask questions politely, many inspecters don't like their authority being questioned.
daveb1 is offline   Reply With Quote
Old 07-12-2012, 08:40 AM   #3
Rewards Points: 79
You didn't say how many layers you put on each side but a 2 hr wall usually means two layers of fire block each side. did you use paper faced (interior) gypsum on the outside? Is that the reason he flunked you? They do also make a type x exterior product with fiberglass facers. Best bet is to find out exactly what he took exception to and try to ask if that was the only problem.
eclark is offline   Reply With Quote
Old 07-12-2012, 08:45 AM   #4
Architect
Rewards Points: 150
This won't satisfy the UL requirement for this 2 hour wall construction.
jcarlilesiu is offline   Reply With Quote
Old 07-12-2012, 08:47 AM   #5
Architect
Rewards Points: 150
They make type "X" gyp. for exterior application.
http://www.americangypsum.com/products/detail/?p_id=137
More importantly, I have never seen anything in the code that requires fire rated construction adjacent to the property line so long as you maintained the required set-back.
I am going to take a look at the code for you real fast, give me a minute.
Old 07-12-2012, 08:56 AM   #6
Architect
Rewards Points: 150
Per the Residential Building Code (verify this is the accepted code for your jurisdiction), exterior building walls constructed less than 5' from an adjacent structure must maintain "1 hour tested in accordance with ASTM E 199 or UL 263 with exposure from both sides.)
Changing out the exterior layer of gypsum board to exterior grade type "X", taping and mudding it, and then house wrap with your finishing system should solve the issue.
Automatic Closet Lights Sav505 Electrical 52 12-28-2012 07:24 AM
Plumb island sink and AAV code for Ajax jhakkim Plumbing 2 02-13-2012 11:07 PM
Please Help - Error Code's 31, 32 and 42 on Carrier 58MVB 100 kolo HVAC 15 01-28-2012 10:13 PM
Lighting proximity to outdoor hot tub - Code Question jeffinpickering Electrical 0 09-12-2011 01:43 PM
Bryant Plus 90 Code 31 ~kirkland~ HVAC 1 03-08-2011 06:14 PM
