Fireproof Mortar - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-20-2008, 05:48 PM   #1
Fireproof Mortar
Hello, Can anyone find what is in Fireproof mortar and what the mix proportions are. I need to build a fireback in refractory bricks and can't find a mix design anywhere.
kirkwood is offline   Reply With Quote
Old 01-20-2008, 08:50 PM   #2
Rewards Points: 6,652
http://www.quickrete.com/ProductLines/Products-Home.asp
Old 01-20-2008, 09:13 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
it seems quik-crete does not make a refractory mortar. Everything I have found is it is a special mortar and is not a simple mix in the field variation of standard mortar.
the only mix I could find for something other than refractory mortar is this fireclay recipe.
Muddox Fireclay Mortar
Fireclay mortar is used when building ovens or fireplaces with firebrick. Mix one part fireclay mortar, to two parts cement, to six parts sand.
Old 01-26-2008, 11:39 PM   #4
remodeling pro
A local masonry supplier will have refractory mortar, it is not something you are going to find at typical lumberyard, hardware store, or big box store.
troubleseeker is offline   Reply With Quote
Old 01-27-2008, 07:13 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I agree with troubleseeker. The Big Home Improvement stores sell what the average home owners need.
Refractory mortar is not in big demand with them.
You can also try Fireplace stores/ fireplace & stove suppliers.
Refractory Mortar Example: http://www.alsey.com/non_water_soluble_mortar.htm
More information: http://www.rumford.com/articleRefmortar.html
- Build Well -
Old 01-27-2008, 08:56 AM   #6
Rewards Points: 1,232
Fire clay is a poor substitute for refactory cement.
Tscarborough is offline   Reply With Quote
Old 01-27-2008, 10:44 AM   #7
Here is a good spot to find Refactory cement in your area:
http://www.rumford.com/store/cms.html
Bad Brick Mortar ??? kourso Building & Construction 21 11-08-2010 12:11 AM
Is it bad to use mortar to level a floor? CB2007 Flooring 4 10-01-2008 08:38 AM
Tile underlayment - mortar bed question Richo Flooring 10 01-01-2008 05:54 PM
Is Structalite up for Tub-setting (instead of mortar?) House_Amuck Plumbing 2 03-20-2007 06:09 PM
can I reuse mortar bed ? mf915 Flooring 1 07-04-2006 07:14 PM
