Fireplace Ticking Noise - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-29-2012, 09:04 PM   #1
fireplace ticking noise
hi i have a gas fireplace which is operated by a key that turns the gas on and then you light it yourself. we are currenty having a storm but there is a ticking noise that is constant coming from where it appears to be the line to the logs. i called the fire department and they could not tell me what the noise could be coming from.
pkoglman is offline   Reply With Quote
Old 10-29-2012, 09:16 PM   #2
the first time it rained after we moved to ohio i heard a similar "tick" in the fireplace. sounded like water was dripping on top of the insert. turned out to be water dripping off the top of the chase for the fireplace and hitting the vent for the combustion air intake on the outside.
Old 10-29-2012, 09:16 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
does your fireplace have a regulator on it? sometimes regulators will make a ticking noise
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-29-2012, 10:07 PM   #4
Too Short? Cut it Again!
Do you light your gas for the logs with a match or does your system have a pilot and ignitor? Is the noise like you get when you turn on the gas to a stove burner and the pilot is out?
Fix ticking noise in pipes insanityitself Plumbing 4 03-19-2010 07:16 PM
Unwanted ticking noise in ducts mmohanna Building & Construction 4 02-22-2010 11:59 AM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 01:17 PM
Heating Duct Ticking Noise mmohanna Building & Construction 6 01-10-2010 12:52 PM
noise from fireplace FRUSTRATEDnKY General DIY Discussions 4 12-24-2007 03:23 PM
