Fireplace Remodel - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-28-2011, 11:56 AM   #1
Lightbulb
Fireplace remodel
I have a solid brick fireplace separating my kitchen and family room. I want to either take it completely out or convert it to gas/see thru fireplace with a less heavy material. I am going to have the floor joists repaired because the fireplace is too heavy. When the repair happens the fireplace bricks will crack. Does anyone have advice on the best way to tackle this?
CHINITAM is offline   Reply With Quote
Old 01-29-2011, 12:06 AM   #2
Registered User
Rewards Points: 5,216
Welcome to the forum! I will bump this for a better response....
Gary
Fireplace Remodel - ongoing ferris13 Project Showcase 26 02-07-2011 11:34 AM
Fireplace remodel -- need advise & suggestions mwehnes Building & Construction 12 06-28-2009 10:36 PM
Fireplace Remodel - Insulation around chimney GeauxCajuns82 Building & Construction 3 01-19-2009 05:30 PM
Help with an old fireplace remodel Atomikk Building & Construction 3 10-15-2008 03:44 PM
Fireplace Surround Remodel baksdak Project Showcase 5 03-06-2008 01:28 PM
