Fireplace Mantel Surround And Building Codes - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-02-2015, 11:54 AM   #1
Rewards Points: 249
Fireplace Mantel Surround and Building Codes
Hey everyone hoping you can help me understand the building code for fireplace mantel surrounds. This is what I'm looking to order for my fireplace:
I want to make sure it meets building and fire code.
The way I read the code is that there needs to be at least 6" clearance from the firebox opening to the surround, and if less than 12", then it cannot project more than 1/8" for every 1" of clearance. So in other words if my surround projected 1" from the brick face then I'd need to have a clearance of 8".
Seems straightforward but I've seen websites and forums that say that's only for above the firebox - not the sides. The sides only need to be 6".
So can anyone clarify for me if there is any difference between the clearance above the firebox versus the sides?
The surround I want is pretty standard and has a projection of 1.5" which would mean that my clearance needs to be 12" which is double what most people have.
I assume/hope I'm not reading the code correctly.
Thanks!
marcus118 is offline   Reply With Quote
Old 11-02-2015, 01:32 PM   #2
Rewards Points: 249
I just spoke to the fire chief in my town and he confirmed my interpretation of the code. So basically I need to be 12" from the firebox on top AND sides. Doesn't that seem like a huge amount of space though? I've never seen a fireplace with that much space...
Old 11-02-2015, 01:46 PM   #3
DIY staff
Rewards Points: 668
It's been years since I looked up the specs--but I have always used 12"(above) --and it never looked odd---
Old 11-02-2015, 01:47 PM   #4
Rewards Points: 249
12" above i'm sure looks fine. i'm just worried about 12" on the sides. the place i'm buying the mantel from tells me the most common clearance on the sides is 6-8" which seems about right to me - but against code apparently!
Old 11-02-2015, 02:00 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 6,056
Note....that is to combustionable materials.
ddawg16 is online now   Reply With Quote
Old 11-02-2015, 02:02 PM   #6
Rewards Points: 249
right. isn't a wooden mantel surround like the photo i posted combustible?
Old 11-02-2015, 02:07 PM   #7
DIY staff
Rewards Points: 668
Sure is combustible---
Old 11-02-2015, 02:10 PM   #8
Rewards Points: 249
my town in NJ uses the standard international residential code. so do people just ignore the code when installing these things?
Old 11-02-2015, 02:11 PM   #9
JOATMON
ddawg16's Avatar
Yes...
Here is a page from the install manual from my fireplace
Old 11-02-2015, 02:42 PM   #10
Rewards Points: 249
Yes...
thanks but the pdf is blank.
Old 11-02-2015, 02:47 PM   #11
JOATMON
ddawg16's Avatar
hmmmm.........your right. So much for CutePDF getting it right.
Lets try this one....
Old 11-02-2015, 02:53 PM   #12
Rewards Points: 249
thanks. i'm guessing this was a factory-made fireplace you bought? there are different rules in the building code for those. my fireplace is original to the house.
Old 11-02-2015, 03:06 PM   #13
JOATMON
ddawg16's Avatar
Yes....double sided. But I would have thought it would be much the same for you.
Building A Tub Surround. HELP? highmarcs Kitchen & Bath Remodeling 2 08-01-2014 08:14 PM
Remodelling den and fireplace doors coyote97 Building & Construction 0 11-22-2013 01:01 AM
width of fireplace wall w/ brick & mantel ugabulldog Building & Construction 5 07-19-2010 10:16 PM
Building a fireplace with no kit l dingman Building & Construction 2 07-17-2009 09:12 AM
