Fireplace Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-23-2011, 03:43 AM   #1
Fireplace Help
Hi,
My house was build in 1945. The fireplace was blocked in about 15 years ago when they put in oil central heating. I have open up the fire place, bricked the bottom and have a free standing grate, I had the chimney swept but when I lit the fire the smoke pours into the room. I have a square opening going up the chimney but either side of that I seem to have bricks and rubble that look like they have been thrown up there and stuck! I am not sure why they are there and if I take them out will my chimney breast fall down. They look like they are held up by fresh air!
CarolJ is offline   Reply With Quote
Old 10-23-2011, 07:06 AM   #2
I question that those bricks are your problem. How high is the top of the chimney with relation to any part of the house within 4'?? The chimney must be 2' above that for a proper draw.
Old 10-23-2011, 08:40 AM   #3
Rewards Points: 36
Who did you get to sweep the chimney? I would reccomend having your chimney inspected by someone who is WETT certified. That rubble and loose brick could be from your liner collapsing.
daveb1 is online now   Reply With Quote
Old 10-23-2011, 08:54 AM   #4
Framing Contractor
Originally Posted by CarolJ View Post
Hi,
Who told you to do that???
Joe Carola
Joe Carola is offline   Reply With Quote
Old 10-23-2011, 09:10 AM   #5
Rewards Points: 2,238
To add to what "Joe Carola" says -
"Bricked the bottom"? -
The "firebox" - the "hearth"?
rossfingal
rossfingal is offline   Reply With Quote
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 11:37 AM
Fireplace construction question scottyv81 General DIY Discussions 1 01-29-2011 09:26 AM
Fireplace Smell ...help wanted ! jasonb72 General DIY Discussions 6 08-26-2010 06:02 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
