Fireplace Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-19-2011, 11:30 PM   #1
fireplace help
I would like to build a fieldstone fireplace and put in a direct vent propane fireplace insert. I would be splitting the stone to 3 inches thick and putting them onto a plywood frame covered by felt paper,wire mesh and a scratch coat. My plan is to go to the ceiling 9ft with a chimney for looks. The unit will built on a 6 inch thick cement floor.
Could there be a problem with the weight of the stone either sticking to the scratch coat or with the plywood structure overall? THANKS
puttputt is offline   Reply With Quote
Old 09-20-2011, 07:27 AM   #2
Concrete & Masonry
Rewards Points: 526
When you say "fieldstone", I think of granite. If that's the case, I think you may have a struggle trying to get 3" thick granite to stick, partially due to the weight & partially due to the density (they don't "grab" well.)
How do you plan on splitting them, and are you sure the floor is 6" thick?
jomama45 is online now   Reply With Quote
Old 09-20-2011, 04:42 PM   #3
fireplace help
Thanks for the reply! I'm from Iowa the field stone here are not granite. They are just stones of various shapes, sizes and textures laying on top of the ground in our corn fields, I am splitting them with hammer and chisel it take time but it can be done if you really study the grain of the rock, Although there are many 4 5 and 6 inch rock across the face that are flat on one side that will work for me the biggest one weighing 6 lbs. 2 and a half inches thick seems to be the norm. I am building this in my garage that I built recently so I'm sure the floor is 6 inches thick and thicker on the edges for the footings.
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 12:37 PM
Fireplace construction question scottyv81 General DIY Discussions 1 01-29-2011 10:26 AM
Fireplace Smell ...help wanted ! jasonb72 General DIY Discussions 6 08-26-2010 07:02 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
