Fireplace Framing Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-17-2008, 06:49 PM   #1
Fireplace framing question
I'm about to frame in a Lennox gas burning fireplace and the instructions say the depth of the framing must be 16 in. and "it is important that this dimension be exact". I'm going to have 24 in. deep cabinets on both sides of the fireplace. Because of this, the fireplace face will probably be something like 26 in. from the rear wall. Why the 16 in. exact instruction? Shouldn't it say 16 in. minimum? Is there a reason I can't have 10 extra inches of empty space between the fireplace and the back wall?
gobble is offline   Reply With Quote
Old 05-17-2008, 09:14 PM   #2
remodeling pro
Not familiar with the exact unit, but since you said Lennox gas fireplace, my thoughts go to the idea that it may be a high efficiency, direct side wall vent unit? If so, that dimension would be critical for the length of the factory furnished pipe connecting the firebox to the exterior vent cap. If it is a vertically vented unit, I can't think of any reason why the depth of the enclosure could not be more than mininum.
troubleseeker is offline   Reply With Quote
Old 05-17-2008, 11:01 PM   #3
This is the unit. It is one of the Lennox high efficient units and is vented vertically. I can't think of anything other than the instruction are poorly written.
http://www.lennoxhearthproducts.com/...ew.asp?pid=371
stupid framing question amakarevic Building & Construction 12 02-23-2008 04:29 PM
fireplace framing sonic_loser Building & Construction 1 11-02-2007 01:35 AM
Framing question dtmbizzle Building & Construction 4 06-14-2007 09:40 PM
Basement Framing Question lpcon Building & Construction 7 04-17-2007 11:18 PM
