Fireplace Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-02-2007, 12:28 AM   #1
fireplace framing
I'm putting in a 4-sided island fireplace in the middle of a 18ft vaulted ceiling room. I'd like to know of a good and solid way to frame above the fireplace as the fireplace is not load bearing.
I've talked to some framers that don't recommend the fireplace but I like the look of the 4 sided fireplace. They said it wouldn't be strong enough and quite flimsy.
I would obviously need to hang the framing from the ceiling but would something like angle iron instead of 2x4s be an alternative?
Any ideas would be welcome.
sonic_loser is offline   Reply With Quote
Old 11-02-2007, 01:35 AM   #2
ICF Construction
Steel framing preferrably 18g framing studs, not drywall studs (usually 20 or 25g).
Depending on your location you may need to special order the 18g.
Chris
Chris Johnson is offline   Reply With Quote
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 09:17 AM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 10:27 PM
Fireplace leaking mmcginn2 Roofing/Siding 4 04-23-2006 11:12 AM
Water leaking over fireplace mmcginn2 General DIY Discussions 1 04-21-2006 12:42 AM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
