Old 09-03-2011, 06:34 PM   #1
Fireplace Doors Insulation
A couple of squirrels got into my fireplace and clawed all of the insulation away from the fireplace doors. The fireplace is not used, except for candles on occasion. Can I replace the lost insulation with foam spray insulation to keep cool air from seeping into the living room this winter? Or, should I replace with fiberglass insulation strips?
Narwal is offline   Reply With Quote
Old 09-03-2011, 09:30 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
If only using it for a decoration, you could probably have a mason cap it up above, so no critters can get in, and also block any drafts. No if you wish to keep it operational, you could look into a gas insert. Check with local Fireplace shops that sell those.
gregzoll is online now   Reply With Quote
Tags
fireplace doors, insulation
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Replacing Doors in masonry wall mwpiper Project Showcase 17 05-12-2011 08:00 AM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 03:10 PM
Old home insulation woes nowwhatnapster Building & Construction 15 11-03-2008 12:59 AM
UGH! A lesson for new Pre-Hung Doors javan General Discussion 6 08-08-2008 08:47 PM
