Fireplace/chimney Repair Options - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 09:42 AM   #1
Fireplace/chimney repair options
A visual and video inspection of my fireplace led to a report stating that I have:
-A gap between flue liner and brickwork of the chimney;
-Large openings between flue liners, as well as longitutinal fractures (in a few places, you can see the aluminum heater liner through a crack in the fireplace flue.
The recommended repair was to remove the firebox to gain access to smoke chamber, repair the system with Chamber Tech 2000 and the Heat Shield Cerfactory Flue Liner Repair system, and install a more efficient firebox.
The cost is in the high single digit thousands. Gulp, says that homeowner! Based on the report, is this the best/most cost effective way to go about this? Does the firebox really need to come out?
Thanks!
sankavarmuch is offline   Reply With Quote
Tags
fireplace repair , flue repair
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 01:42 PM
Transom window repair options (with pictures) barlav Windows and Doors 4 06-14-2011 07:31 AM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Concrete driveway repair options monkey3605 Building & Construction 5 08-18-2006 04:15 PM
