-   -   Fireplace advice (http://www.diychatroom.com/f19/fireplace-advice-7186/)
always something 03-17-2007 10:34 PM
Fireplace advice
I would love to compare notes with either someone who installs fireplace liners or someone who has had one installed and has no smoke problems
clasact 03-18-2007 08:25 AM
what kind of fire place I put in a vent less run by propain.I had a few problems at first but once I got the logs right it fixed all that and it works great
always something 03-18-2007 09:40 AM
it is an open wood burning fireplace it is just for looks and not to heat the house. Maybe its a smoke making fireplace:laughing:
clasact 03-18-2007 01:17 PM
no it heats the whole downstairs the problem was I didnt have the crematic logs positioned corectly and it was causing some smoke even through it is a propain fireplace you have got to have your loge place corectly
always something 03-18-2007 07:03 PM
well yes i have tried the positioning of the logs and yes id does make a
difference but i can only burn 1 log at a time and it has to be right at the back of the fireplace,I also raised the stand and it is still the same.
AtlanticWBConst. 03-18-2007 07:58 PM
Check your smoke stack and it's air flow.
Smoke stacks don't just allow the smoke to go up and out, they are supposed to literally 'pull' the smoke out.
I would start investigating your smoke stack arrangement and connections...
always something 03-19-2007 07:59 PM
smoke stack? is that the same as a liner because the contractor that
installed it said that i was a one piece but it does not come all the way
down to the flue door which i would have thought it would have. if not then i do not know what a smoke stack is:huh: .
AtlanticWBConst. 03-19-2007 08:43 PM
In your case, your fireplace flue....the whole chimney itself....
It should basically be sucking up the warm smokey air and venting it out without any additional overflow smoke, unless something is wrong with the air flow....
Normally, when you have a fire, even at the initial start of it, the smoke should just get 'sucked' right up. Sort of like what happens when you light a match next to a leaky window. The cold air suctions out the warmer air...
That is why I suggest looking at issue with the air flow...the flue...
Se this link:
http://www.woodheat.org/chimneys/chimneys.htm
