#1 |
Fireplace
I want to remove brick surround on fireplace. Can I leave the wood burning insert and sheet rock over it.
#2 | |
JOATMON
FireplaceQuote:
Yes you can.....assuming that they brick is not supporting anything else. You need to confirm that you do just have a fire box with a brick facing....
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Residential Designer
Fireplace
Sorry Chloe but there is no general answer to your general question.
You need to find out how the brick is placed around the fire box and if the fire box is a zero clearance type or not. A zero clearance will allow combustible materials in close proximity to it, some others will not. In short, you may be able to and remain safe or may not, we need more information. Andy.
Residential Drafter/Designer To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to AndyGump For This Useful Post: | sdsester (07-07-2012) |
#4 |
Stuck in the 70's
Fireplace
Who is the manufacturer of the wood burning insert?
If you can find out I would suggest googling them. Their website should give you instillation instructions and the minimum distances to combustibles. Last edited by Blondesense; 07-07-2012 at 01:43 PM. |
| Display Modes | |
| How to go about replacing fireplace surround? | NewHomeDIYGuy | Remodeling | 9 | 01-26-2012 10:56 PM |
| Fireplace construction question | scottyv81 | General Discussion | 1 | 01-29-2011 10:26 AM |
| Fireplace Smell ...help wanted ! | jasonb72 | General Discussion | 6 | 08-26-2010 07:02 PM |
| New project: removal of old fireplace-replace with a new fireplace! | MrShadetree0222 | Building & Construction | 14 | 10-16-2008 07:12 PM |
| Possible to build direct-vent fireplace? | DIYerself | General Discussion | 3 | 12-22-2007 11:07 PM |
