Fireblocking Revisited? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-25-2008, 01:41 PM   #1
Beer Advocate
Taipans's Avatar
Rewards Points: 150
Fireblocking revisited?
I asked about my cities fire blocking requirements and this is exactly what they responded with.
The space that requires fireblocking is at the top where the wall meets the ceiling. Blocking will prevent the movement of air from the wall cavity to the ceiling joist cavity(s).
Since I will have 2x4 stud walls running up to the joists set in 1inch from the wall how to I satisfy this code? Expecially along the wall thats parallel with the joists?
Thanks!
Taipans is offline   Reply With Quote
Old 02-25-2008, 03:23 PM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
I'm up against the same thing. You have to insert blocking between the joists next to the wall.
My building inspector told me I could just use Great Stuff (blue) but this didn't work so well.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 02-25-2008, 03:34 PM   #3
Beer Advocate
Taipans's Avatar
Rewards Points: 150
So what they are saying is the space between the studs and the concrete foundation cannot have an open gap to the joists above. I was trying to figure out how to seal "above" the wall in every single joist space. Since you don't want to just stick wood between the top plate portion against the wall wonder what else would suffice?
Old 02-25-2008, 03:44 PM   #4
Rewards Points: 26
Can you rip a 5" or so peice of fire rated drywall and screw it to the joists and then butt your top plate up to the drywall? By this i mean put a peice of drywall inbetween your joists and top plate of the stud walls, and exted the drywall to the foundation to block off the air space.
ponch37300 is offline   Reply With Quote
Old 02-25-2008, 04:12 PM   #5
Beer Advocate
Taipans's Avatar
Rewards Points: 150
Are you asking if I can do that or if it will satisfy the code? If your saying that will work then it sounds like an easy fix.
Old 02-25-2008, 04:16 PM   #6
Rewards Points: 26
I am not 100 percent positive if it will meet code but i don't see why not since you can use 5/8" fire rated drywall on ceilings to meet fire code. You would have to ask your inspector or hopefully someone else can say for sure. You would probably also have to use fire caulk to seal the edge of the drywall that meets the foundation. Hopefully this will work for you.
Old 02-25-2008, 04:19 PM   #7
Beer Advocate
Taipans's Avatar
Rewards Points: 150
Can't believe how many things pop up like this when all you want to do is make a small living area. Biggest issue though is no one knows, not even the city! So its like you take a huge risk and might have to rip everything out once your done because you "just dont know".
Old 02-25-2008, 04:36 PM   #8
Building and plumbing
USP45's Avatar
Rewards Points: 150
fire blocking is established with the top plate. This seals the air from the joists, if the walls are taller than 8 feet, then blocking must be put in at 8 foot. Also if you install a drop ceiling then fire blocking is required at the bottom of the drop ceiling in the studs (where the drop ceiling will be at)
USP45 is offline   Reply With Quote
Old 02-25-2008, 08:32 PM   #9
Beer Advocate
Taipans's Avatar
Rewards Points: 150
Ok so the top of the framing is the top plate which means when building a normal stud wall its never something that crops up. But since mine is set away from the wall an inch what is reccomended to "seal" up that small area between the top plate and the foundation?
Thanks!
Old 02-25-2008, 09:56 PM   #10
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
2 x wood stock (seal edge gaps with fire-stop caulking) - or - Use a fire-rated Mineral Wool Fibre insulation like Roxul.
- Build Well -
Old 02-26-2008, 05:24 AM   #11
Beer Advocate
Taipans's Avatar
Rewards Points: 150
Thanks!
Horizontal Fireblocking? Armitage Building & Construction 2 01-06-2008 04:40 PM
Ramset Revisited 27 caliber bjr23 Tools 7 07-01-2007 05:01 PM
