Fireblocking, Boxed In Areas? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-04-2008, 06:53 AM   #1
Beer Advocate
Taipans's Avatar
Rewards Points: 150
Fireblocking, boxed in areas?
When putting up my framing I have ran into a handful of areas that have pipes running down them. Right through the area the top plate needs to go. With the city needed 100% fireblocking around the walls how do you guys suggest dealing with the pipes? For instance, the main water line comes in at ground level and runs up the basement wall into the ceiling. Do I need to "notch" out a 2x4 to go around this?
Its probley a silly question, but I am learning as I go!
Taipans is offline   Reply With Quote
Old 03-04-2008, 05:27 PM   #2
Electrician
They also make fireproof insulation which is used alot around here for that type of installation.
chris75 is offline   Reply With Quote
Old 03-04-2008, 06:02 PM   #3
hvac/refrigeration
We use metal to fire stop these areas or you can use plywood.If it is not cut tight fit it must be sealed with fire caulk in my area. It doesn't have to be fire rated.just stop draft areas where in case of fire it doesn't run up the chase.
metal-maniac is offline   Reply With Quote
Old 03-05-2008, 05:23 AM   #4
Beer Advocate
Taipans's Avatar
Rewards Points: 150
Easy enough, thanks guys!
painting large areas farrington135 Painting 10 02-17-2012 05:52 PM
Uneven areas in tile backer Richo Flooring 1 01-04-2008 07:33 AM
High low areas in my lawn jerry1967 Landscaping & Lawn Care 3 11-28-2007 11:46 PM
When/how to seed grass in dead areas? curls00 Landscaping & Lawn Care 8 07-29-2007 12:25 AM
grey areas on my vaulted ceiling wasierski Building & Construction 1 07-22-2007 02:38 AM
