Fireblocking Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-13-2009, 01:55 PM   #1
fireblocking basement
can someone put this in simpleton terms for me? i asked my village inspector if fireblocking in the basement is code. this was his reply;
"Fireblocking is required at intersections of walls and drop ceilig also
where perimeter walls meet the floor system, there usually a void on the
back side of the wall".
only 1/2 inch drywall is required and he also said that insulation will work for fireblocking.
thanks gents
phospher is offline   Reply With Quote
Old 03-13-2009, 02:09 PM   #2
Remodeling Contractor
Between floors any chase (open space) must be sealed with an approved fire blocking material. This is to prevent heated air by a fire rushing through this space rapidly spreading a fire. So if you have a soffit (ceiling) it needs to be fire blocked at the lower intersection with a wall. Each exterior wall along your perimeter between floors needs to be fire blocked. This is typically done with a 2X4 block. Even any penetration along the wall plates between floors needs to be fire blocked. These holes are caulked with a fire retardant caulking. For retro-fit you can just stuff mineral wool insulation into the larger spaces and fire retarding caulking in areas where pluming or electrical lines go through the floor/wall junction.
Old 03-13-2009, 02:13 PM   #3
DIYer
jpsmith's Avatar
DIY Chatroom moderator, thekctermite, has been keeping this great thread going that covers this subject in detail:
How to fireblock framing
You should find your answers there. I know I did.
-Jack
jpsmith is offline   Reply With Quote
Old 03-13-2009, 02:49 PM   #4
i've insulated all floor joists in the basement so would that cover the "the floor system"?
Old 03-13-2009, 03:22 PM   #5
Read the other posts as suggested. Just click on the blue letters. The joist insulation is not the issue. The issue is the space at the edge of the room where a wall above or below intersects. Just this 4" perimeter is what we are dealing with to stop air flow from one floor to the other.
Old 03-14-2009, 01:07 AM   #6
Registered User
Termite's Avatar
Read my post that JPSmith linked to. It'll answer your questions and there's lots of pictures and illustrations to make it easier to understand.
No, insulating the floor won't do anything as far as fireblocking. Unfaced fiberglass can be used as a fireblock, typically packed in a space tightly to block it off.
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 12:21 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
