Fireblock With Spray Foam Application Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-06-2011, 09:47 AM   #1
Fireblock with spray foam application question
Will fireblock spray foam adhere to polyethelene? I have poly on the wall in the basement with 2x4 framed out an inch from the wall. If it will not stick to the poly will it stick to the wood framing and even if it does is this up to code?
toobhed is offline   Reply With Quote
Old 10-06-2011, 10:56 AM   #2
Rewards Points: 93
By fireblock spray foam, I am guessing you are talking about Great Stuff? I have tried it on Owens Corning XPS and wood. Great Stuff sticks to both.
I don't believe spraying foam between the polyethylene and the framing is up to fireblocking code, since polyethylene is highly combustible. Check with your local inspector to be sure.
leungw is offline   Reply With Quote
Spray Foam Installation Problems Ron6519 Building & Construction 7 07-11-2011 02:50 PM
Can I spray foam myself, is it affordable. oceaneer Insulation 8 05-13-2011 07:15 PM
DIY spray foam kits HitLines Building & Construction 4 03-18-2010 01:58 AM
Insulating with spray foam and caulking willowgirl Building & Construction 71 01-09-2010 09:42 AM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 08:12 PM
