Fireblock Basement Soffits - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-07-2010, 12:25 AM   #1
NE78FJ40's Avatar
Rewards Points: 18
Fireblock basement soffits
This is one of the requirements I'm dealing with.
602.8 Fireblocking required: At all interconnections between concealed vertical and horizontal spaces such as occur at soffits, drop ceilings, and cove ceilings.
The inspector said I need to fireblock my soffits. I didn't totally understand where this needed to be done. In the pictures, where and how do I need to fireblock these soffits?
Fireblock basement soffits-dscn1110.jpg   Fireblock basement soffits-dscn1111.jpg   Fireblock basement soffits-dscn1112.jpg
NE78FJ40 is offline   Reply With Quote
Old 03-07-2010, 01:41 PM   #2
NE78FJ40's Avatar
Rewards Points: 18
Anyone have any ideas?
Old 03-07-2010, 03:34 PM   #3
Registered User
Rewards Points: 526
Page #4: http://www.codecheck.com/cc/images/CC5thEdSample.pdf
16" of compressed unfaced batt insulation in all stud bays facing the ducting soffit, the height of said soffit. Key word---- INTERSECTIONS. The top plate of the wall next to the soffit stops fire but the void at soffit/wall stud bay doesn't. Where a vertical wall adjoins a horizontal enclosed space (soffit). I suggest fiber at every 10' along the soffit as well, though not required. If you get a fire in a light housing, it could travel in the floor joist bay to the soffit, to anywhere the other joists go from the soffit.
Floor/ceiling draft stopped if >1,000sq. ft. & ceiling hung from floor joists.... 502.12 concealed space under stairs and at top and bottom of stringers.... 602.8
Did you read KC's Fireblocking "how to" discussion where you also posted your question at?
Be safe, Gary
Old 03-07-2010, 06:21 PM   #4
NE78FJ40's Avatar
Rewards Points: 18
Yes, I've read the whole topic a couple of times.
Old 03-07-2010, 06:44 PM   #5
Registered User
Rewards Points: 526
Imagine your drywall on the soffit bottom against the stud wall. Where it butts the wall is where the insulation or other approved fire-blocking needs to be. At the intersection of the soffit's ceiling (horizontal) and the wall's vertical joint.
Be safe, Gary
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
