Fire-Retardant Coatings For Wood Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-12-2011, 07:47 PM   #1
Rewards Points: 115
Fire-Retardant coatings for wood framing
Does anyone have any experience or knowledge about fire-retardant coatings? I've found these but can't find any reviews or peoples' experience with them:
http://noburn.com/products/no-burn-wood-gard
http://www.flamecontrol.com/hr_coating_n.html
http://www.firefree.com/ff88.php
Thanks!
6fthook is offline   Reply With Quote
Old 07-13-2011, 06:26 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
I've used Flame Control's latex coating. No different than using regular paint. I think they make a flat and a semi-gloss.
Old 07-13-2011, 08:41 AM   #3
AGWhitehouse's Avatar
Originally Posted by Patiosclotures View Post
These structures especially during the framing stage are very liable to fire. Once the structure is completed, the wood dries out over time leaving a very unstable mass of fuel to burn. Fire retardant spray coatings prevent ignition of the treated substrate. In the case of a fire, the lightweight building materials and construction methods in use today make homes and businesses vulnerable to structural failures within minutes.
How is this really relevant to the OP question? We all know dried wood burns...
AGWhitehouse is offline   Reply With Quote
Old 07-13-2011, 02:59 PM   #4
Rewards Points: 115
Thanks for the posts guys
Trying to find out if there is a difference between the products I linked to in regards to performance. Just looking for something that delays ignition or at least raises the ignition temperature of the wood, not concerned about performance if the coating if it is actually on fire.
Old 07-13-2011, 03:25 PM   #5
concretemasonry's Avatar
Rewards Points: 2,650
This reminds me of a group of Russian contractors looking at U.S. construction and the their first question was "Why do you build homes out if firewood?". They were accustomed to more permanent, safe and durable construction. - They were very polite and did not ask the builders and contractors out of courtesy face-to-face, but dumped it on me because they knew me. The biggest thing was when they questioned me on was a model log home with a fireplace.
Dick
concretemasonry is online now   Reply With Quote
plywood on fire rated wall acerunner Building & Construction 9 11-18-2016 06:15 PM
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 01:56 PM
Framing on Top of Insulation kothep Building & Construction 14 08-15-2009 02:48 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 08:38 PM
