Fire Resistant Mortar - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-08-2010, 09:45 PM   #1
fire resistant mortar
We are building a pizza oven in our kitchen, wondering if anyone has advice on mortar so that it will not crack, is it better to locate a refractory mortar supplier or make up a mixture using fire clay, sand and cement? Has anyone heard of a product called pearlite being used in the firebox?
buzzard69 is offline   Reply With Quote
Old 07-08-2010, 10:33 PM   #2
Concrete & Masonry
Rewards Points: 548
For interior use, this is what I prefer:
http://alsey.com/airset_fireplace_mortar.htm
As for the "perlite", look for an insulsting castable for what you need. Perlite can be mixed in with Portland to do the same, but I'd still recommend a re-mix if you're on alearning curve.
jomama45 is offline   Reply With Quote
Old 07-08-2010, 11:12 PM   #3
Thanks for getting back to us, We will locate the refractory mortar. We have already used a mortar mix that resulted in some cracking, should we go over the cracked surface or remove existing layer and do it again? We also have a steel door in the firebox section, will the refractory mortar be able to expand as the metal heats and expands? We would like to avoid cracking in the mortar render around the door area. Is refractory mortar what we should be using on the inside of the firebox over the sand and firebrick base, or do we need to use something else with the direct flame/ heat?
Fire Pit on Gravel unclenanoose Landscaping & Lawn Care 8 10-29-2010 07:48 PM
Plan to install new fiberglass tub; questions about process for mortar underneath lazzlazz Kitchen & Bath Remodeling 1 05-02-2010 04:53 PM
Do I need Fire Resistant Drywall for this new room? vseven Drywall & Plaster 6 12-19-2009 03:00 PM
Basement Concrete Block Mortar Seepage Advice Nightcrawler Building & Construction 6 09-22-2009 08:57 PM
fire resistant material ttas123 Carpentry 1 02-10-2008 03:49 PM
