#1 |
Fire Rated Plywood
How to you determine if Plywood is fire rated? I am building a new garage, was told by permit dept, that I need fire rated plywood, I am shopping on the internet, trying to determine if a product is fire rated.
Thanks Cathy Camp Taylor, KY |
#2 | |
Fire Rated PlywoodQuote:
http://www.buyleedlumber.com/product...-wood/plywood/ Your local lumber yard should be able to order this for you along with the rest of the needed materials.
Ron "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." B. Franklin 1759 |
#3 |
Civil Engineer
Fire Rated Plywood
I believe that all fire retardant plywood is rated by Underwriters Laboratory (UL) and bears the mark FR-S on the wood. If you don't find such a mark, it is not rated. There are a number of companies that make fire rated plywood, I think Hoover is the largest. You may not be able to get this product at the average big box store, you may need a real lumberyard.
#4 |
Experienced
Fire Rated Plywood
Welcome cwatts50, to the best darn DIY'r site on the web.
Here another link, fire rated materials should bear a stamp on them which will define the fire rating specification for which the material meets. http://fireratedlumber.com/ Mark
When its all said and done there is usually more said than done To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#5 |
Framing Contractor
Fire Rated Plywood
Go to a real lumberyard and find out. They will tell you exactly what you need.
Joe Carola |
#6 |
Fire Rated Plywood
I think you need to go back to the building/inspections dept and clarify that. I've never heard of any area REQUIRING something as odd as fire retardant plywood. Most depts that require a fire rated wall will specify it by an hour rating, not the materials used to get that rating. I can assume this garage is attached to living quarters or has living quarters above it.
#7 | |
Experienced
It is more likely the requirement is as you state between the garage and the dwelling. Mark
#8 |
Fire Rated Plywood
its also more red in color , its seen more in my area for duplexes and townhomes
#9 | |
Architectural Designer
Original Poster: I would clarfiy with your building department whether they only require the rated plywood against the home, or if they require the whole roof. The inspectors will look for the stamp mentioned above when inspecting for approvals...
Life's too short...so enjoy it! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| Fire rated doors. What does it mean? | DIY_Diva | Building & Construction | 4 | 04-21-2011 11:34 PM |
| Structured Wiring Panel Location...Fire Rated Wall??? | RICKM15752 | Electrical | 0 | 04-20-2011 12:30 PM |
| Fire Rated Wall? Need to place structured wiring panel. | RICKM15752 | Building & Construction | 0 | 04-20-2011 01:21 AM |
| Can I tile over old plywood with no gaps? | JFERTICH | Flooring | 5 | 02-21-2011 03:52 PM |
| Can I use Thin Set Mortar over Interior Grade Plywood? | JFERTICH | Flooring | 1 | 02-19-2011 06:08 PM |
