Fire Rated Plywood
How to you determine if Plywood is fire rated? I am building a new garage, was told by permit dept, that I need fire rated plywood, I am shopping on the internet, trying to determine if a product is fire rated.
Thanks Cathy Camp Taylor, KY |
http://www.buyleedlumber.com/product...-wood/plywood/ Your local lumber yard should be able to order this for you along with the rest of the needed materials. |
I believe that all fire retardant plywood is rated by Underwriters Laboratory (UL) and bears the mark FR-S on the wood. If you don't find such a mark, it is not rated. There are a number of companies that make fire rated plywood, I think Hoover is the largest. You may not be able to get this product at the average big box store, you may need a real lumberyard.
Welcome cwatts50, to the best darn DIY'r site on the web.
Here another link, fire rated materials should bear a stamp on them which will define the fire rating specification for which the material meets. http://fireratedlumber.com/ Mark |
I think you need to go back to the building/inspections dept and clarify that. I've never heard of any area REQUIRING something as odd as fire retardant plywood. Most depts that require a fire rated wall will specify it by an hour rating, not the materials used to get that rating. I can assume this garage is attached to living quarters or has living quarters above it.
It is more likely the requirement is as you state between the garage and the dwelling. Mark |
its also more red in color , its seen more in my area for duplexes and townhomes
Original Poster: I would clarfiy with your building department whether they only require the rated plywood against the home, or if they require the whole roof. The inspectors will look for the stamp mentioned above when inspecting for approvals... |
| All times are GMT -4. The time now is 12:02 AM. |
