Fire Rated Doors. What Does It Mean? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-21-2011, 04:37 PM   #1
DIY_Diva's Avatar
Fire rated doors. What does it mean?
Hi,
So maybe this is a stupid question, but I'm curious what the different time ratings on fire-rated doors mean. Does 20 minutes mean that the door will withstand fire for 20 minutes, then start burning? Why do they have time ratings and not some other system of rating?
Thanks. I'm trying to figure out if I need a fire rated door and what it all means.
DIY_Diva is offline   Reply With Quote
Old 04-21-2011, 04:45 PM   #2
Experienced
Jackofall1's Avatar
The fire rating you almost got right, but it starts burning when there is a fire, but it will withstand a fire for 20 minutes before it burns through.
I am curious as to what kind of door you are looking for, such as the door between the house and a garage, would need to be a 2 hour rating I believe.
Mark
Old 04-21-2011, 04:58 PM   #3
Civil Engineer
Rewards Points: 4,856
You need a fire rated door if the building code for your specific application requires a rated door. The actual meaning of the rating is not so obvious; it is a function of the exact type of test that is run, and should not be taken to mean that the door will withstand a particular fire in your house for the rated time. In general, the higher the rating, the longer the door will protect the occupants from a fire on the other side, but not necessarily for the minute rating of the door.
Daniel Holzman is online now   Reply With Quote
Old 04-21-2011, 05:01 PM   #4
DIY_Diva's Avatar
Thanks for the responses. I'm just wondering what kind of door to get for a child's bedroom. Fire-rated to what degree.
Old 04-21-2011, 10:34 PM   #5
Residential Designer
AndyGump's Avatar
Rewards Points: 686
Send a message via Skype™ to AndyGump
Afraid the kid is going to start fires?
Andy.
AndyGump is offline   Reply With Quote
The Following 2 Users Say Thank You to AndyGump For This Useful Post:
RickyBobby (04-22-2011), rossfingal (04-22-2011)
French Doors Don't Meet In Middle tima2381 Building & Construction 11 03-07-2011 05:42 PM
1 hour fire rated ceiling sith type c 5/8" Gypsum La Casa Building & Construction 0 12-11-2010 06:23 AM
Do Floor Installers Usually NOT Trim Doors? thebigsee Flooring 20 11-22-2009 09:14 AM
Masonite pre hung doors sticking hot weather Pawl Carpentry 4 07-08-2008 04:26 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 05:04 PM
