Fire Rated Buildings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-07-2011, 01:45 PM   #1
Fire rated buildings
Can you have exterior soffit vents under cantelievered living space in a Type V (1 hour) rated building?
Mrlemonade is offline   Reply With Quote
Old 12-07-2011, 08:31 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
No.
If I understand the question, that is.
But no.
Andy.
AndyGump is offline   Reply With Quote
Old 12-08-2011, 06:45 AM   #3
Rewards Points: 6,652
Someone is trying to get a forum to do their homework Andy.
The Following User Says Thank You to gregzoll For This Useful Post:
AndyGump (12-08-2011)
Old 12-08-2011, 09:27 AM   #4
Had the same problem a while ago. Sourced some intumescent vents from England.
Marvel is offline   Reply With Quote
Old 12-08-2011, 12:15 PM   #5
Too Old
If you can show a 1 hour fire rating for a soffit vent then you can.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 12-08-2011, 02:04 PM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
You can use a vent with a linked fire shutter. Just be sure the vent is rated for horizontal application.
plywood on fire rated wall acerunner Building & Construction 9 11-18-2016 06:15 PM
Fire Rated Plywood cwatts50 Building & Construction 8 08-07-2011 04:48 PM
Fire rated doors. What does it mean? DIY_Diva Building & Construction 4 04-21-2011 10:34 PM
Structured Wiring Panel Location...Fire Rated Wall??? RICKM15752 Electrical 0 04-20-2011 11:30 AM
Fire rated walls chek77 Remodeling 3 01-26-2009 09:10 PM
