Old 03-25-2011, 05:11 PM   #1
Fire Proofing Spray Foam
I just found out that my crawl space is considered a basement because the furnace ducting runs through it... despite being 5 ft high.
I had the basement sprayfoamed and I have to fire proof it (and not just cover it with an ignition coating).
Are my only options:
- Drywall (or similar)?
- Concrete (shotcrete)?
Drywall is not a great option, even the moisture resistant stuff, because the basement is a bit musty and there is sand.
Is it possible to DIY shotcrete at a reasonable price? Time is not an issue. I can take forever to do it.
or, is it possible to buy a fire rated spray foam and just spray on a surface layer?
Any other ideas?
billyh is offline   Reply With Quote
Old 08-05-2011, 01:36 PM   #2
Any other ideas?
Spray-applied rockwool. "FireStop TB" www.usfireproofing.com
material costs averages about .42 a sqft and is a true thermal barrier that protects the foam and not just a fire retarder like the coatings. It has been tested and approved over all manufactures open and closed cell spray foams and is considered an equivalant to drywall. It costs a 2/3 less than a coating.
stevegorman is offline   Reply With Quote
Spray foam insulation troyce1 Building & Construction 9 05-24-2011 07:57 PM
DIY spray foam kits HitLines Building & Construction 4 03-18-2010 01:58 AM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 10:03 AM
spray foam - headers and flat ceiling biglumber35 Building & Construction 2 05-02-2009 12:40 AM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing 2 09-19-2008 08:12 PM
