Which Fire Blocking Caulk To Use Around... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-14-2013, 03:15 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,344
Which fire blocking caulk to use around...
3M offers 3 different fire blocking caulks. Red, Yellow, and Gray.
For these applications which fireblock caulk should I use?
1. I added steel fireblocking around the chimney, now I need to seal the metal to the chimney.
2. there is blocking in the stud bay that separates the floor system from the wall. There are some gaps and I need to seal it.
TIA
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 12-14-2013, 05:05 PM   #2
Rewards Points: 3,130
All I've ever used to seal fireblocking is firestop foam. Didn't even know there was caulk for that purpose.
Old 12-15-2013, 09:16 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,228
I have used the red intumescent caulking a bunch of times with similar projects.
Works well.
Old 12-15-2013, 03:16 PM   #4
Registered User
Rewards Points: 5,498
http://www.atlassupply.com/manufactu...protection.htm
Gary
Old 12-16-2013, 06:54 AM   #5
I have gas!
Thanks guys...
Gary I've got a quick general question about the descriptions.
Do you have any idea what " NON-RATED construction" means? This phrase is in the FB136 description. Is it OK to use the FB136 around gaps at the perimeter of the floor system?
Old 12-16-2013, 07:45 AM   #6
AHH, SPANS!!!
Rewards Points: 1,166
the expanding foam is the best by far as far as application goes. the hard caulk does not apply well and does not fully fill holes easily. when you add the expandable version it fills all voids and more...
hand drive is offline   Reply With Quote
Old 12-16-2013, 10:33 AM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
Most residential work is non-rated, so FB136 will work fine. 3M makes a number of different sealants for different applications. Gray, Red,
Yellow and Blue. You really don't need more than what the FB 136 will provide.
If you were sealing rated walls or floors in a commercial structure, FB 136 would not be permitted.
3M's fire stop website has lots of information.
http://solutions.3m.com/wps/portal/3...beTGS9R7QM25gl
Old 12-16-2013, 09:32 PM   #8
Registered User
Lotsa Garys here...lol.
Gary (the real one)
Gulf Island Building. cocobolo Project Showcase 8228 11-17-2015 02:02 AM
Fire Blocking Basement buildit45 Building & Construction 2 07-17-2012 09:34 PM
What type of Caulk to Use Einhorn General DIY Discussions 19 08-21-2011 02:50 PM
Sanded vs non-sanded caulk sukhenkoi Kitchen & Bath Remodeling 1 05-17-2011 06:48 PM
Recaulking Bathroom Help RaeEllen Remodeling 9 07-25-2008 10:23 PM
