Old 12-22-2012, 10:39 PM   #16
Moderator
Fire Blocking Basement
Whoops, because I said it wrong... PIR (foil-faced insulation board); http://www.buildingscience.com/docum...roperty-table/
PIC is polyisocyanurate; https://docs.google.com/viewer?a=v&q...4EyM707m0gPdXQ
Sometimes called "isocyanurate" or just "iso"; http://www.buildingscience.com/docum...some-materials
Locally, at Lowe's; http://www.rmax.com/downloads/DataSheets/rmp3.pdf
In the previous link, Figs. 11,12, and 15 (rim); Whoops, because I said it wrong... PIR (foil-faced insulation board); http://www.buildingscience.com/docum...roperty-table/
In the link I gave previously, Fig. 11, 12 and 15 (rim joist); http://www.buildingscience.com/docum...lation-systems
Gary
Clothes taking longer to dry?
Old 01-23-2013, 08:02 PM   #17
How are guys fireblocking the basement walls that use the xps foam board directly in contact with the wall method (and 2x4 wall in front)? Install the XPS, then you have to cut strips in the XPS to get a 2x4 in direct contact with the concrete wall (caulk Seams)? Just curious.
AllGoNoShow is offline   Reply With Quote
Old 01-24-2013, 01:27 PM   #18
I am looking for the same feedback.
I have already put up the 2 inch XPS boards from the concrete floor to the floor joists. I have already put in XPS board and foam sealed the rim joists.
I am ready to frame in front of my XPS but want to do the fire blocking that is required and want to ensure I do it correctly.
Rooki is offline   Reply With Quote
Old 01-24-2013, 04:53 PM   #19
Moderator
I recommend working with your local AHJ, as he/she will be inspecting it =wiring, plumbing, egress, etc. for the paper trail to satisfy your HO Insurance carrier if ever a claim. Some read the fire-stop as a 2x against the concrete-every 10', others, only above the frame wall to concrete, ask them; prescriptive codes (added amendments per locale); http://publicecodes.citation.com/ico...002_par018.htm
http://publicecodes.citation.com/ico...002_par031.htm
Gary
Old 01-26-2013, 12:37 AM   #20
Do a search for fire blocking. At one time there was a very knowledgable B/O here. He and his wife had a child, now he has other priorities.
fireguy is offline   Reply With Quote
Old 01-27-2013, 09:01 PM   #21
Gary
My town guy who does the inspections is hilarious (read-lazy). When he inspected the egress window he went down to the basement, said it looked "fine" and issued me my compliance letter. Apparently he is so good he could eyeball the half dozen measurements that need to be met to have an egress window to be code...makes passing inspections easy tho!
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 11:09 PM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 11:50 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
Is blocking required for ceilings? ChrisJJ Drywall & Plaster 3 08-22-2010 11:47 AM
Fire blocking? Can you use liquid nails? Leoskee Building & Construction 8 09-16-2009 12:02 PM
