Old 12-12-2010, 07:28 AM   #1
fire barrier for foam board insulation
Hi,
I am about to add foamular 250 board the interior surface of my foundation (crawl space). Owens Corning states that the foam board must be covered with a 15 min fire/thermal barrier like 1/2" drywall. I'd rather not use drywall, would covering it with stucco work?
jcomp is offline   Reply With Quote
Old 12-12-2010, 08:03 AM   #2
Stucco is heavier than drywall, and considerably more time intensive. How was the insulation installed?? Might not support the weight.
Vapor barrier & insulation for basement floor dvsanfor Flooring 5 09-26-2010 11:01 PM
Really confused about vapor barrier and insulation JakAHearts Building & Construction 11 06-16-2010 10:54 PM
Radiant Barrier + Insulation with Metal Roof customfab Building & Construction 8 02-16-2010 10:47 PM
Insulation vapor barrier DIYminer Remodeling 1 01-04-2010 03:38 PM
Moisture Barrier behind cement board code? scoot_gt Building & Construction 8 09-29-2007 09:53 PM
