Old 04-22-2011, 07:42 PM   #1
Finishing a window after drywall?
What types of wood, trim and materials will be needed to finish a window after the drywall is hung? Hope I framed it right.
nateshirk is offline   Reply With Quote
Old 04-22-2011, 09:09 PM   #2
firehawkmph's Avatar
Need some pics Nate.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 04-24-2011, 01:01 AM   #3
Sorry. I guess I just assumed there was one common way to do it. What was I thinking?
I leveled the 2x4's with the top most lip on the outer edge of the window, so whatever I use to finish it will but right up against the window.
Here you go.
Finishing a window after drywall?-dscn0260.jpg   Finishing a window after drywall?-dscn0261.jpg
Old 04-24-2011, 08:29 AM   #4
You can do it a few ways. If you want to use molding around the window or not.
If you like the molding route, you can either frame it like a picture or install a sill and apron on the bottom and trim out the other 3 sides with the moldings of your choice. You can use 2 1/4" wide molding up to 6". You can use a single molding or add a back banding to it.
I'd search for window trimming and look at the various pictures or you can just match what you have in the rest of the house.
Matching the rest of the house is the norm.
Ron
Old 04-24-2011, 08:50 AM   #5
old guy contractor
tcleve4911's Avatar
Lots of ways to trim a window.....
tcleve4911 is offline   Reply With Quote
Old 04-24-2011, 11:06 AM   #6
Along with what Ron said, do any wiring, insulate and drywall. Then measure and cut some jamb extensions which will but up against your windows and be flush with the drywall. Decide if you want a sill or not and pick out your trim. One suggestion I would make is to visit either a local lumberyard or a millshop that carries decent trim. Forget the big box stores for this part.
Mike Hawkins
Old 04-24-2011, 03:14 PM   #7
i had a pretty good idea of how to do it. I just wasn't sure what types of wood to use, proper nailing techniques, and things like that.
Mike Hawkins
So it's jamb extensions I'm looking for. I think it could get as deep as 7 ". Will I have a problem finding it that deep?
Thanks for the replies. I think I got it now.
Old 04-24-2011, 03:27 PM   #8
Tizzer's Avatar
I'm not sure why you need anywhere close to 7" extensions from what I see. I would print out one of those pictures or one standing back. Take it to a lumber yard, they can point you to all kinds of trim and the nails.
Tizzer is offline   Reply With Quote
Old 04-24-2011, 03:42 PM   #9
The window is against a 2x4. That's 3 5/8". Add to that the wall material, say 1/2" sheetrock and you're at 4 1/8". All you need is a 1x5 or 1x6, ripped to width.
Ron
Old 04-24-2011, 08:44 PM   #10
Well, it seems I thought the jamb extension would go as deep as it had to until it hit the window, which is why I said 7". And I just measured, and after the drywall it actually goes as deep as 8". Is this going to be possible or am i going to have to reframe around the window (wider)? I'm sure it's going to be easy to just say to reframe, since it's just some random guy on an internet forum, but I'd like to hear any possibilities.
Oh. And I don't have a table saw. Another problem? Ugh....
Old 04-24-2011, 09:02 PM   #11
the Musigician
DangerMouse's Avatar
A smaller, less expensive 7¼" table saw will do what you need to do for about $50.00.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 04-24-2011, 10:46 PM   #12
Cool. i'll look them up.
Old 04-26-2011, 09:14 PM   #13
I think I'm going to end up spending closer to $200.
So is an 8" deep sill going to be ok?
Old 04-26-2011, 09:22 PM   #14
the Musigician
Sure! Plenty of room for the cat to sit in the window that way.
....or a plant?
DM
Old 04-26-2011, 09:42 PM   #15
....or a plant?
DM
AAAAAHHHHHH! You don't even want to me to get into the cat. She felt the need to p!$$ in every corner in the basement. Every time I try to soak it up with cat litter, and clean it up, it's back a day or 2 later in one of the corners. My wife comes up with this idea to put plastic bags in the corners, since she doesn't like them, and you know what she did? Yup. P!$$ed on those too. At least it's easier to clean up like that. but I think she's going to have to "dissappear" before the basement is done.
drywall to window mort5029 Drywall & Plaster 4 02-24-2011 10:53 AM
My window between siding and drywall... jamieofansa Drywall & Plaster 2 09-05-2010 09:55 PM
Finishing Densarmor Plus Drywall daveyd Drywall & Plaster 11 04-24-2009 04:06 PM
Finishing a Basement Window Dan OBrien Carpentry 3 01-04-2009 09:56 AM
tools for finishing drywall sedwick Building & Construction 8 04-21-2007 09:23 AM
