Finishing A Vaulted Ceiling, Double Vapor Barrier? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-18-2009, 02:31 PM   #1
Finishing a vaulted ceiling, double vapor barrier?
Our house is built with clearspan metal trusses with purlins fastened on top of the trusses. When it was built, a layer of some of that reflective foam insulation was put over the purlins and then the metal roof went on top of that.
Now we are wanting to finish the inside, and I am wondering how it should be insulated. We were thinking of filling the stud cavities with fiberglass insulation and then putting more of the foam insulation (its about 1/4" thick) underneath that. We would then put sheet rock under the foam insulation. So it would be the sheet rock, a layer of the foam insulation, fiberglass in between the purlins, another layer of foam insulation on the purlins and then the metal.
My question is, would that be bad to have two vapor barriers?
Thanks.
the.toy.box9 is offline   Reply With Quote
Tags
ceilings , insulating , vapor barrier
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Vaulted Pine T&G Ceiling Jambo Diego Building & Construction 1 05-08-2009 06:59 AM
Vaulted Ceiling - (Pictures included) How to do it? peabodyn Remodeling 7 03-29-2009 12:18 PM
finishing a drywall ceiling mmhendrie Building & Construction 12 03-17-2009 10:11 AM
Vaulted ceiling rakuz66 Building & Construction 1 03-02-2008 08:50 PM
