Old 07-24-2009, 01:17 AM   #1
Default finishing under your deck
We recently built a cottage with a nice walkout basement. We used pressure treated lumber for our top level deck and didn't put much thought into what would happen if we were on the ground floor and it was raining (rain coming through deck).
I have seen a couple of underdeck options, but there all white and all our soffits are black. Does anyone have any other unique ideas on how to finish this off so we can enjoy the bottom deck even when it's raining but still look great?
zob_888 is offline   Reply With Quote
Old 07-24-2009, 08:01 AM   #2
corrugated plastic and let it drip into a gutter and downspout. very easy install and not too hard on the wallet. even the gutter system is plastic
II Weeks is offline   Reply With Quote
Old 07-24-2009, 08:01 AM   #3
There are metal and vinyl systems for installing under a deck to catch rain. None are black, but I suppose you could paint the metal ones black. Painting vinyl a dark color is not recommended. I can't recall the manufacturers of these systems, but will try to find it.
More On This Topic
Whether you need a garage for your vehicle or extra storage it will be a wise investment for your home. The plans for a garage can be purchased off the Internet instead of using a high priced architect because of the simplicity of the design. If you want... Read More »
Finishing a deck can seem like an intimidating task with the different products and materials used. However, it doesn't have to be overwhelming when you break everything down into steps and figure out exactly what you need to get the job done. Read More »
Hi, I'm John Jackson from Remax Suburban in St. Louis, Missouri. I'm here today to talk about how to buy a house for Expert Village. As you move from house to house and you try to decipher the pros and the cons of each individual house, the very first... Read More »
What Is a Pressure Washer?
What Is a Pressure Washer? by Expert Village
Hi I'm CR Willey with Expert Village today. We're going to teach how to clean and pressure wash your houses, driveways, pool decks. This is my buddy Darren. First thing you want to do is wear rubber boots, some loose fitting clothing. I preferably like... Read More »
A new deck may be just the addition your home needs. Patios are perfect for relaxing evenings, backyard barbeques and family gatherings. The process of constructing a deck can be time-consuming and expensive, especially when it comes to buying the lumber... Read More »
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 07:07 PM
Post detail for raised covered deck jogr Building & Construction 3 05-16-2009 09:46 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 01:17 PM
Sanding and Finishing a New Deck?? Ler0y Jenkins General Discussion 4 07-24-2008 09:49 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 05:37 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
