Finishing A Room In The Basement - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-14-2011, 08:44 PM   #16
DIY staff
Rewards Points: 7,174
In a nutshell--to raise the drain----rent a chipping hammer (hand held jack hammer) --
Chip out enough concrete to expose enough of the pipe to glue on a coupling and another short section of pipe.---done---
Then you will need to fill in the low spot with a latex modified patching cement---trowel it out--Done--
That's the nut shell version---feathering in the cement when it is very thin may require a second type of patching compound---we will get all detailed if you choose to go this route.--Mike---
Old 12-14-2011, 08:52 PM   #17
Rewards Points: 5,336
Originally Posted by infamshxr View Post
Ok, then 2". Lol i'm not home so i'm guessing. I
The drain is about the size of a shower stall drain. As far as dricore, it probably works good, but i'm sure is much more expensive than just leveling it off. Also, I think someone asked, there is a dump pump on the other side of the basement
That was "sump pump".
Ron
B. Franklin 1759
Old 12-14-2011, 09:38 PM   #18
Would have to do that feathering thing or is that not necessary? And yea sry. Stupid auto correct. Lol
infamshxr is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Finishing Basement Wall - Stairs Along Concrete Rob1976 General DIY Discussions 5 02-02-2011 08:39 AM
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 09:41 AM
Finishing basement laundry room DIYguy2000 Building & Construction 7 12-04-2009 11:56 AM
Finishing basement (jackpost question) silky General DIY Discussions 11 04-27-2009 04:26 PM
