Finishing My Upstairs Attic<--Help! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-15-2009, 11:11 AM   #1
Finishing my upstairs attic<--Help!
Hey guys,
I am going to be finishing the upstairs of my cap cod in northeast Ohio. I have pulled up all of the retro 70's carpet that was here when I bought the house. The photos show a mismatch of plywood that was installed as a subfloor. I am wondering should I rip up all of the pre-existing subfloor and lay down new plywood?? The depths range from 1/4 to 3/4, currently. If I do need to rip out and put in new, what depth should I install over the floor joists? I would like to install a bathroom upstairs, so eventually I would be putting in a tub/shower, along with tile.
Can anyone point me in the right direction?
Thanks!
Finishing my upstairs attic&lt;--Help!-attic-001.jpg   Finishing my upstairs attic&lt;--Help!-attic-002.jpg
lilerm8302 is offline   Reply With Quote
Old 02-15-2009, 11:21 AM   #2
Remodeling Contractor
if it is uneven, rip it out. Then use 3/4" T& G plywood. For the tile area you will need to add one more 1/2" plwood
Old 02-15-2009, 12:13 PM   #3
what size are the floor joists? 2X10's 16" OC ?
and be careful ripping out the old plywood. Pull out every nail or screw or you could damage the floor joist. PIA I know. probably wont be too many and if your floor joists are strong enough then like mentioned above, 3/4 T&G screwed down with construction adhesive.
II Weeks is offline   Reply With Quote
Old 02-15-2009, 01:33 PM   #4
An attic with 2 X 10... that would be one strong ceiling. These are normally 2 X 6 at best they can hope for 2 X 8. Which means he should also sister new joists so they become 2 X 10. But also we need to know what bearing walls are supporting this attic area. What spans are above any bearing walls.
Old 02-15-2009, 02:03 PM   #5
Rewards Points: 5,336
Before you close up the floor with all that plywood, make sure you have planned out the wiring and plumbing. If necessary ,plan on a subpanel up there and run the main line from the panel in the basement to the place upstairs the subpanel will be.
Ron
Old 02-15-2009, 02:34 PM   #6
Why a sub panel for two circuits. I would run a 12/3 to a junction box.
Old 02-15-2009, 04:12 PM   #7
I was figuring, Bath(1 or 2 circuits right there), lighting, outlets, maybe an A/C or two. A subpanel is cheap insurance to unanticipated expansion.
Ron
Low water pressure upstairs but gauge reads 100psi? rivers72 Plumbing 7 11-15-2008 07:55 PM
HVAC Upstairs QUESTION Statecowboy HVAC 1 09-15-2007 11:15 AM
Finishing Upstairs Bonus Room luner99 Plumbing 5 02-26-2007 03:34 PM
Plumbing questions - finishing upstairs bonus room luner99 Building & Construction 1 02-07-2007 07:12 PM
baseboard heat upstairs not working TraceyLee HVAC 1 10-23-2005 05:47 PM
